so after use..any tips on removing oil/finger grease from the keycaps? it just looks awful..shiny keys on the most hit caps..and dull on those that are never hit ;/
Dust doesn't stain, it's obviously a skin oil/dead skin grime issue. Putting a cover on it WILL reduce dust, but it won't reduce the appearance of skin oils on the keys.Originally Posted by 78@pwnt4lif3;12786776
This is what i do.. you use the mechanical keyboard right? Take out the plastic cover that came with the box and use it as a shield WHEN you are NOT using the keyboard to prevent dust or spills. When it's time to clean. I use Microfiber Cloth and Rubbing Alcohol to keep it clean from germs and anything sticky. Last resort is Cyber Clean GOO which works good but i rarely need that anymore. I rarely have anything sticky nor dirt. I clean it once a week same as my tower. Great keyboard!
Just FYI. Taking off keycaps voids your warrantyOriginally Posted by DorkSterr;12783629
Same question here. And another thing are all the keys removable because some of my keys won't come off, I feel like using a wrench to yank it out.
