Can I add 120mm fans to a 280mm radiator?
2 reading
4.7K views 13 replies 8 participants last post by  ermandadana
#1 · (Edited)
Hello, I just finished ordering a Kraken x62 and my question is if I can add 120mm fans to that heatsink. I'm thinking of the QFR1212GHE but I don't know if it will have matching holes to place the 120mm fans. Thank you very much in advance. All the best.
#2 ·
How are you going to add 120mm fans to a 140mm rad?
You can but you are going to need an adaptor and the fans might be more trouble than its worth as they are very thick which means they might not even be able to fit inside the case
Short answer no
#5 ·
Get 140mm radiator, use 140mm fans. Simple as that.
Reactions: VirusF
