We are proud to announce that the SMH10 is now shipping. (6.5" shorter than the STH10).
The SMH10 is available "flat-packed" (unassembled) to save on shipping or fully assembled.
Both XL-ATX and HPTX form factors are available (exterior case dimensions are the same).
Features (standard equipment):
Case Configuration Options:
ATX Layout: Standard (N/C), Reverse (N/C)
Form Factor: XL-ATX (N/C), HPTX (N/C)
MB Door: Ventilated (N/C), Solid (N/C), XL Window (20.00), XXL Window (30.00)
Lower Chamber Covers: Ventilated (N/C), Solid (N/C)
PCI Back Plate: Fan Holes (N/C), Hex Mesh (N/C)
Packaging: Flat-Pack/Unassembled (N/C), Assembled (N/C)
Specifications:
Size: 25.75"H x 26.56"D x 11.25"W (654mm x 675mm x 286mm) *
PCI Slots: 10
Form Factor: XL-ATX (13.60" x 10.75") or HPTX (13.60" x 15.00" - 346mm x 381mm)
Max Radiator Size -Top: 120.4 using integrated mount.
Max Radiator Size - Lower Chamber Side: 140.4 (Mounts not Included)
Cooling Tower Clearance: 180mm
Flex-Bays (5.25" Bays): 13
HDD Capacity: 2 native (18 using Flex-Bays) plus 4 native SSD's
Weight: 27 lbs.
Compartment sizes (inside frame dimensions):
Middle: 26.00"(660mm) x 9.70"(246mm) x 17.44"(443mm)
Lower: 26.00"(660mm) x 9.70"(246mm) x 7.41"(188mm)
Inside width door/covers: 11.12"(282mm)
* Note: Sizes shown are for the case only. Rubber feet add .75" (19mm) to height, optional casters add 2.63" (67mm).
Price: $499.95
More information to come…
- All aluminum construction - .090" (2.3mm) chassis .063"(1.6mm) doors/covers
- Choice of ventilated or solid doors and covers (on a panel by panel basis)
- Slide out MB tray with Tech Station conversion kit
- Dedicated Mounts for 2 HDD's and 4 SSD's plus one 3.50" Bay
- Choice of hex mesh or 40mm fan holes on PCI back plate
- Dual PSU mounts (Support bracket available: MAC-123)
- Extensive room behind the MB tray for wire & tubing management.
- Four single bay filler plates and three triple bay cover plates
- Filler plates for top and bottom radiator openings, MB Chamber and 40mm fan openings on MB tray (if selected), PCI slots, and three PSU covers
- Four sets of mounting brackets for 5.25" devices (MAC-125)
- Lamptron anti-vandal style switches (power & reset) and wiring harnesses: blue ring for power and red dot for HDD activity. They are standard switches that can be easily swapped out for custom color combinations.
- Four rubber feet with screws (casters are available: MAC-107)
- Misc. hardware: Thumbscrews, MB standoffs, Tie-wraps, etc.
- Available in black or white matte
Specifications:
PCI Slots: 10
Weight: 27 lbs.
Price: $499.95
