I just bought the Elite 360 to function as my HTPC rig with the occasional gaming. It's for my room at the fraternity house to try to go with something smaller. I also got the Corsair H50 as it's a good, small cooler. As I see it with this case, it has 2x80mm fan holes in the back and 1x80mm on the bottom. It also has a 120mm on the side and one on the top. I currently have 2x120mm CM Red LED fans, 1 120mm fan with the H50, 1 120mm fan with the 360. I need to decide the best way to intake/exhaust the air, and if buying 80mm fans will help, which fans to buy. The only thing I know I plan on doing is putting the radiator on the top. Any ideas?
