Hello,i am thinking about buying ax1200i but as i read many people complain about the fan clicking noise.Is this a common problem?Or should i just buy the ax1200 without having any trouble?
You dont need a new PSU its a waste of moneyOriginally Posted by ozzy1925
thanks all for the much information.Currently i have corsair hx 850 v1 which is almost 4 years old.This time i want something very powerful for at least for 5-6 years because i may upgrade my pc components like quad gpu etc.
The best psu i can get in my country either ax 1200 or ax1200i .I want to buy ax1200i and i need more 1200i user opinions about the fan clicking issue.
its not Seasonic madeOriginally Posted by NYMD
I have a new 1200i because its what I could get locally. I'd choose the 1200 since it is Seasonic made and the 1200i is not. But the 1200i is still a very good PSU and I cannot hear any clicking. The fan doesn't even turn on until the PC is under load and by that time, you will probably have many other fans going on in the system. Anyway, no clicking here, it is a solid unit.
This. I wouldn't go for high wattage power supplies that aren't extremely high quality OEMs because it's even more dangerous with that amount of current and
^^^ You are correct. It is the AX850 that is made by Seasonic; neither of the 1200s are.
Even the best OEM can make something bad
i find this
No it drops your efficiency
