I need help with FPS if you guys can post up your 1.6 FPS settings..and if you can post how to make the game better looking...thx
Originally Posted by moe356 I need help with FPS if you guys can post up your 1.6 FPS settings..and if you can post how to make the game better looking...thx |
Originally Posted by simon741 What does antistropic filtering do? |
Originally Posted by bigval You know how the lines looked ripped and rugged with it off? On ledges, gun corners etc. The more you have, the more they will look perfectly smooth and nice since they blur the edges of the pixels more and more so that everything blends in properly. The AF makes you be able to see distance better, and allows you to see more clearly when an object is far away. However, the best thing to do to make a game look better, is make the resolution really high like 1280x1024 as it compacts in more pixels, allowing for a much clearer and sharper image. |
Originally Posted by AZNracerx1989 Get NGO v 1.5.8.... Best driver ive used for cs 1.6 has an open gl switcher for older games like cs 1.6 in it's folder!!! ![]() ![]() |
