Crucial 128 GB m4 CT128M4SSD2 Firmware update version 0309
1 reading
8.8K views 13 replies 9 participants last post by  terraprime
#1 ·
it says to make a bootable cd...my question is can I use a cd? or do I need to use a dvd
#7 ·
Originally Posted by s-f-r-j View Post
How do you update firmware? Could somebody help me or provide tutorial.
Thank you
How to update M4 firmware via CD:
  1. Have your SATA mode set to AHCI or IDE.
  2. Download 0309 firmware here: http://www.crucial.com/support/firmware.aspx
  3. Burn the .iso to a CD.
  4. Boot from the CD.
  5. Type "yes" when prompted to.
  6. Wait for it to complete.
  7. When complete turn the PC off.
  8. Turn said PC back on.
  9. Boot from SSD.
  10. Enjoy your updated Crucial M4.
How to update M4 firmware via USB:
  3. Download and run this: http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
  4. Select "Try Unlisted Linux ISO (New Syslinux)
  5. Browse to your Crucial SSD .ISO-file
  6. Select your USB drive
  7. If your USB drive is not formatted (Fat32) check the box
  8. Click "Create"
  9. Click "Ok"
  10. Reboot from the USB
  11. Type "yes" when prompted to.
  12. Wait for it to complete.
  13. When complete turn the PC off.
  14. Turn said PC back on.
  15. Boot from SSD.
  16. Enjoy your updated Crucial M4.
#9 ·
Originally Posted by Cape Cod View Post
When do you get the ssd?? I got mine last week and it already had the 009 firmware on it. You can look at the sticker and it will tell you.
Only asking because you may not have to update
The newest is 0309...I think you may want to update yourself.
#10 ·
i dont think 009 and 0309 are the same thing...
#14 ·
