Included in the Crysis 2017 Mod compilation.What does a 2007 game look like with some mods.
(Bonus Textures and shaders will also work on Crysis Warhead.)
1.
a.Top 5 Time Of Day files with installers.
b.Better Textures/Objects with installers.
c.Improved shader files with installers.
Download- https://drive.google.com/file/d/1tBUB2-gIy0tFyuL8RCQUTZLM-BH6zEuX/view?usp=sharing
2.
Top 5 ,Time Of Day files with Stand alone installers.
Download- https://drive.google.com/open?id=0B273Qp8fBbjbSHVGNGdIY2tocWs
Read the read me in the download.
I take no credit for the mods.List of mods used in the read me.
Video Crysis 2017 Mod files used-if lights are to bright for you ,you can delete the shaders files in ZPatch2.pak and delete ZPatch3.pak
a.Installer RELI2ToD - RELI2 By Hawkeye Time Of Day Files Of Day Files
b.Install Flare HDR Normal -HDR Normal with Anamorphic Lens Flares(Blue) + WaterWaves + Improved Shaders
c.Install Textures - Updated Textures From Original
a.Installer BFMUTOD - BlackFire's Mod Ultimate Update 1.3 Time Of Day Files
Some Screen shots from different installers
Crysis_HDR_Bright_Lens_Flare
https://postimg.org/image/kyqnkexmj/
Crysis_HDR_Normal_Lens_Flare
https://postimg.org/image/kpt2uhku3/
Crysis_Mster_TOD
https://postimg.org/image/my79btry3/
Crysis_Naturl_TOD
https://postimg.org/image/fgy1wm2ez/
Crysis_No_Water_Wave_No_Flare
https://postimg.org/image/jkz0p3yd7/
Crysis_Water_Wave_No_Flare
https://postimg.org/image/mgc3vz2d7/
Crysis_BFMUTOD
https://postimg.org/image/m9yesvt8b/
Crysis_CCCTOD
https://postimg.org/image/ongcjw7nf/
Crysis_RELI2_To_D
https://postimg.org/image/5apgdmi0r/
How to install.1.Best results is to play in devmode.Also for Mods to work Correctly.ADD(-devmode)to crysis target line in shortcut to game.Looks like:Electronic Arts\Bin32\Crysis.exe" -devmode2.Always Delete Shader Cache files before adding new Shader files to avoid errors.(C:\Users\yourname\Documents\my games\Crysis\Shaders\Cache)3.Unzip/extract all files to game folderElectronic Arts\Crytek\Crysis4.Click on the Installer You would like to try,your choices are.a.Install Flare HDR Bright -HDR Brighter Than Normal HDR with Anamorphic Lens Flares(Blue) + WaterWaves + Improved Shadersb.Install Flare HDR Normal -HDR Normal with Anamorphic Lens Flares(Blue) + WaterWaves + Improved Shadersc.Install Textures - Updated Textures From Original(See List Below) + No Anamorphic Lens Flares + No WaterWaves + Improved Shadersd.Install WaterWaves - No Anamorphic Lens Flares(Blue) + WaterWaves + Improved Shaderse.Installer BFMUTOD - BlackFire's Mod Ultimate Update 1.3 Time Of Day Filesf.Installer CrysisTOD -Original Crysis Time Of Day Filesg.Installer CCCTOD - Cuban-Ultima-Doom-Assassin47-Taowolf-Sword's Custom Crysis Configs [CCC] [Triple "C" Pack] VERSION 2.21 Time Of Day Filesh.Installer MsterTOD - Mster Config v3.01 FINAL Time Of Day Filesi.Installer NaturlTOD - Natural Mod 2.0.2.Time Of Day Filesj.Installer RELI2ToD - RELI2 By Hawkeye Time Of Day Files5.Uninstall Filesa.Uninstall Time Of Day Files- Click On Installer CrysisTOD.bat- (This will install Crysis default Time Of Day Files)b.Uninstall Flare HDR Bright or Flare HDR Normal or WaterWaves -Delete ZPatch3.pak in this Folder(Electronic Arts\Crytek\Crysis\Games)c.Unininstall Textures - Delete ZPatch2.pak(Electronic Arts\Crytek\Crysis\Games)6.If you want to use any modded files for the Crysis game and use the installers just unzip your modded files(Looks like this EG:z_xxxx.pak) and overwrite the files in this folder ZPatch1 Thanks to all the modders.I take no credit,just put some files together for easy installing and easy sorting of your Crysis mods.7.To load all weapons/cheats press` in game to open console and type exec autoexec.cfgBind keys arebind 6 time_scale 0.3 - Slow down timebind 7 time_scale 1 -Restore Timebind 9 cl_hud 0 -Clear Hudbind 0 cl_hud 1 -Restore Hudbind 8 r_drawnearfov 2 -Change Field of viewbind i r_drawnearfov 1 -Restore Field of viewbind u ai_ignoreplayer 1 - Enemies ignore playerbind o r_depthoffield 2 -Depth of Field onbind p r_depthoffield 0 -Depth of Field offIncluded Mods full or part used.AY-69Ammo Boxes SXL & Radioactive-ContainerAsian AAA Black skinAsian APC amphibious camo desert skinAsian APC camo desert skinAsian Heli grey rusty skinAsian Smallboat camo snow skinAsian Truck red used look skinBow & ArrowBloody NanosuitC4 SkinChicken Textures-No HD Grass (bug with grass)Civilian Car Rat skinCrysis Expanded TOD FilesCrysis HD Textures Pack 2016Crysis_Moac_Custom_DarkCrysis W.H. FY69 Crysis FGL40 Crysis FY71 BCrysis_Gauss_AmphitryonCrysis Hurricane black customCrysis LAW Crysis Scar Nano CarbonCrysis_Shotgun_AmphitryonCrysis_SMG_Old-Used-LookCrysis Socom BlackCrysis TAC gun us desertXzero/Condros/CRYZENX ShadersCustom Terrain POM TexturesGlobalAmbientLighting_pom_AfHawker TattooHigh Resolution GrassJP_foods_v2Laser Pack-REDLTV red used look skinNettle flowerNew forestNK Chinese CamouflagePepper's Full weapon sound packPure BloodReli2 InstallerRygel TexturesRadiatorSilents TexturesSlicer91's HD Texture PackStarwaster Water ShadersTire pomUltimate_Assault_ScopeUs solidersUS VTOL seams&bolts skinXtreme Particle Chaos
1.
2.
Crysis_Mster_TOD
Crysis_Naturl_TOD
Crysis_BFMUTOD
Crysis_CCCTOD
Crysis_RELI2_To_D
