1 - 6 of 6 Posts
BTK
Discussion starter · #1 ·
Im at the level "all the fury" and I have killed every single KPA in the whole level......it says secure the container......and its right here and nothing is happening
I've had things like this happen to me in Crysis (I don't have Warhead), and the only fix was to go back to a previously-saved game and start over from there because the current game-save somehow ended up getting corrupted. So restarting the current one (from the most recent game-save file) might have the same result.
So, you might even have to go back to the previous checkpoint.
Looks like a bug. Hope you have an earlier save you can play form.
Discussion starter · #4 ·
I have some other saves I can try I looked online for guide and it says you go climb up the watchtower at the very end of the level and press f on the radio but when I look at the radio there is no option to press "f to use"
Then either something is still incomplete, or this particular Save is corrupted.
It's possible that there may still be a Korean running around somewhere, completely lost. Or stuck against a wall, or worse yet: several hundred feet below the map. I would just load the previous Save and have some additional fun. :)
The radio part comes after the container has been secured and after the radio comes the big laser/plasma gun part. Try an earlier save. The container should become "secured" once the near by enemies have been killed.
1 - 6 of 6 Posts
