DDR5 motherboard with iGPU support that can handle 6000+ MT with XMP?
6.8K views 34 replies 11 participants last post by  Elrick
#1 · (Edited)
FNG here, I'm a bit overwhelmed in my research, so finally decided to reach out here for some expert opinions.
I'm trying to build a new PC, mainly for video editing (Resolve) and to a lesser degree some occasional gaming (non-competitive). I was pretty set on getting an Asus Z690 (or maybe Z790) Hero motherboard and 2x32 GB of G.Skill 6400 CL32 memory (F5-6400J3239G32GX2-TZ5RK). However, upon further research, I have found numerous people having serious issues getting XMP to even POST with Asus boards, including the Hero. I plan to get the 13900K in case that matters.
The issue seems to affect 2x16 GB kits, so I'm guessing my 2x32 would also have problems. It's unclear to me if this is an Asus BIOS issue or not, as discussion seem to be ongoing. I've also read positive results with the MSI Unify X board, but that one doesn't support iGPU and I really want Quick Sync. Although I'm a bit of an Asus fanboy, I'd be willing to jump ship to MSI or ASRock if they have good and stable offerings. I'd like to avoid Gigabyte.
I don't have to buy anything this week, but I have some components sitting on my shelf (case, cooler, PSU, etc.). Motherboard and memory (and CPU) have yet to be purchased, so that's why I'm asking for some guidance.
Is my best bet to downgrade to DDR4 and try to find some decent motherboard? I really like Asus, but they no longer make their nicer boards in DDR4, so I'd be left looking at a TUF Gaming, or maybe something from MSI. Or is it possible that the DDR5 issue may be resolved sometime soon via BIOS updates? I have no real desire to manually overclock my RAM for extra performance, I just want to be able to run a stable XMP profile and edit my videos. I just don't understand where this XMP problem is coming from for those affected.
I would like to play with overclocking the CPU, but honestly I may just end up slightly undervolting it for temperature reasons, that is yet TBD, but not a big driving factor right now. Stability is, though.
Anyway, let me know your thoughts on this DDR5 XMP issue, especially as far as 2x32 is concerned, or if you have MB/memory recommendations. I no longer trust the QVL.
#2 · (Edited)
You see the most complaints about Asus because it has the biggest user base(at least on this forum look at Asus threads vs MSI and other manufactures threads). All ddr5 MB manufacture have similar issues.
Go with z790 MB if you go ddr5, they do better running higher clocks than z690 ddr5 MB. I think something like a Hero should run 2x32 at 6000 to 6400 fairly easy.
Look at the Gskill QVL list, not that I trust QVL list but I would put more faith into it than the manufactures. F5-6400J3239G32GX2-TZ5RK - QVL - G.SKILL International Enterprise Co., Ltd.
Or their ram configurator for a MB your interested in RAM Configurator - G.SKILL International Enterprise Co., Ltd.
#3 ·
I'm fine with that, the money difference isn't a big deal breaker, but I read multiple reports of Asus Z790 not even POSTing with DDR5 6000, that's why I'm asking here. Of course you could be right in that they sell more boards, but I wanted to get this community's take on the situation. I'd be fine with a 6000 kit, I'd like to get the fastest setup I can at this time without RMA-ing half of the build later to downgrade to DDR4, if that makes sense.
#4 ·
Are you planning on overclokcing much? Hero doesn't make much sense if you don't.
Most Z790 boards can do 1DPC 2R at 6800+, so I don't see why 6000 would be an issue. AMD has a weaker IMC, so they are stuck at 6200-6400 due to cpu constraints. ntel has boards going up to 7800+ but you will need to manually set them up as those are crazy OC values. XMP just means the settings have been tested by the manufacturer, that does not mean it is just plug-and-play on any board.
DDR4 is not a downgrade, DDR5 is not at a point yet where it performs any better. This is the biggest miss on the current AMD AM5 boards, especially since their IMC is so far behind even of that of Intel.
Reactions: Horgh
#5 · (Edited)
To give you an idea, I'm still on a overclocked 4790K on a Hero VII board, so I'm so far behind the curve that I'd probably be happy with a newer toaster. But on a serious note, I'm trying to build a video editing rig that can also play some games, and since I haven't spent money on build in a very long time, I'm ok to try to go after the latest and greatest at this point. The reason I was looking at the Hero board specifically is that it has Thunderbolt connections on the back and I like Asus' Aura out of all the RGB software I've seen. Since they don't make a DDR4 version, that's what pushed me to DDR5. If everything could remain stable, I would definitely tinker with overclocking the 13900K, after all what's the point of a K processor otherwise? :)
If I go DDR4, I think the MSI Tomahawk is looking promising, but that is currently my backup. I think with DDR4 the 13900K can handle 4x16 without noticeable problems compared to 2x32, correct? I'm asking since I'd be looking at two fast 2x16 kits at that point probably.
I also realize XMP doesn't necessarily mean plug-and-play, but I'm trying to see if I can still achieve that.
#6 ·
Plenty of people running DDR4 64 Gb over 4000 Mhz G1 on this forum.
4x16 is only realistically doable with Micron Rev B as it is SR, but this ram is no longer made.
2x32 Gb decent DDR4 is very difficult to find new, again Micron Rev B was and still remains the best ram for either 4x16 or 2x32.
If you don't already have it, you are going to struggle to find it. DDR5 2x32 6400 is BETTER than DDR4 2x32 3600.
DDR4 2x32 / 4x16 4000+ is better than most 64 Gb DDR5 configurations, as it is extremely difficult to get 7000+ DDR5 with 2x32 or 4x16.
So unless you can find 64 Gb DDR4 that can push 4000+ low timings, you are much better off going for DDR5 2x32 6400.
Reactions: Sheyster and Horgh
#7 ·
Again, my preference would be to go DDR5, I just got scared by the reports I found, some on Reddit (yeah, I know...) and some on dedicated forums. If the consensus here is that I can get a Z790 Hero board and should be able to XMP that G.Skill 6400 (or 6000) memory, then I'm willing to roll that dice. But if the consensus is that I'll struggle to get it running on XMP, I'd like to know.
You say DD4 is hard to find, but wouldn't this fit my bill, for example? G.SKILL TridentZ RGB Series 64GB (2 x 32GB) 288-Pin PC RAM DDR4 4000 (PC4 32000) Desktop Memory Model F4-4000C18D-64GTZR - Newegg.com
#8 · (Edited)
I hope your not talking about the people trying to run 4x16 on ddr5 6000+ and using them as examples. Because the z690/z790 are daisy chain and will struggle with 4 dim vs 2. This has been known for a long time about daisy chain vs t topology.
2x32 will be easier to run on ddr4 or ddr5 z690/z790.
I cant say I have seen people having issues running ddr5 past 6000 on z790 MBs. There might be some but it is not common.
#10 ·
.I hope your not talking about the people trying to run 4x16 on ddr5 6000+ and using them as examples. Because the z690/z790 are daisy chain and will struggle with 4 dim vs 2. This has been known for a long time about daisy chain vs t topology.
That's a valid point, and I've been trying to make sure I'm not looking at the 4x configurations, but here is one thread of a guy claiming failure with DDR5 6400 2x32:
I've seen a few others, some on tom's hardware forum, and one other I can't find.
#12 · (Edited)
I thought you were talking about people post in the Asus z790 thread about running ddr5 past 6000. Like I said if I went off the whole internet I could find people who have issues with everything.
Edit from what i have seen in general Asus, MSI and Gigabyte are all doing pretty good with z790 ddr5. Not many run 2x32 so feedback about that is limited.
#27 ·
6400 MHz DDR5 on a Z690 Strix E here. It will run this speed with XMP (I've never had any POST issues with either this kit or the 5600 kit that preceded it), but I have timings set manually.
Right, but that's 2x16, I was asking about 2x32. Fortunately since then I got the 6400 2x32 GB kit to run in XMP 1 and 2, and it seems stable. I haven't tried to push it harder yet, but that's the next step.
#32 ·
Yes, Z790 Hero Maximus, I can't select XMP or XMP2 with my 6600s, I have to manually lower it to 6000, for Corsair 64-bit 4x16 RAM :(
Running two 32GB of 64GB (total) GSkill's on my Z790 Steel Legend.
They are set at 6400Mhz speed, no deviation whatsoever running them on XMP setting (from GSkill).
Never had any problems when using any memory sets from that Manufacturer, my personal favourite in the World today.
#35 ·
Good for you, you're lucky. Corsair SVQL, a very good brand of 4x16, doesn't work for me. I have to stop at 6000 instead of XMP at 6600 by default.
I also wasted money on TEAM DDR5 64GB sets. Both of them wouldn't run at their 6400Mhz designated speed. Instead, I was forced to noble them down to 6000Mhz. So yes, even I get screwed by some memory manufacturers with their bogus claims.
GSkill never lies when it states the actual speed on their packaging. Hence, my instant fanboy love for this manufacturer. They have never failed me ever, and I've been buying GSkill for over a decade.
But, I don't have Steel Legend.
Substandard compared to an Asus Board simply because they have the world's best BIOS. Truly jealous despite having another manufacturer's board.
Only bought it because it supports 8 Sata connections for cheap and their IO plate provides extras that I use on my desktop.
It's an Asus ROG Maximus Z790 Hero.
Damn fine bit of kit there :love: . YOU need to get some GSkill's, and you will enjoy the performance and reliability.
Never go cheap on memory because you will pay in other ways.......
