I have xonar dx audio card but it doesn't have optical input so I plan to buy optical to 3.5mm converter head about 2 bucks on ebay to use with my optical cable. I just wonder if it can give me 5.1 surround sound? thanks.
Which card do you have?
This^Originally Posted by cjc75
What speakers are they?
Manufacturer and Model?
Just about ALL 5.1 speakers for the PC have 3 .. 3.5mm connectors, to plug into 3 jacks on the sound card.
Can you provide a link to the speakers on the manufacturers website, and also link the manufacturer specs of the sound card?
this is the speakers : http://store.sony.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&partNumber=DAVHDX589WOriginally Posted by cjc75
This.
Use your video card's HDMI output?Originally Posted by kyo1992
no guys, my receiver doesn't have any 3.5 mm but optical and HDMI inputs. So what do I have to use to get 5.1 from my computer ( which is xonar DX audio card) to connect to the receiver (link) to get 5.1.
The standard 3.5mm jack will not. But if you are using a SPDIF cable which is TOSLINK, then the sound card sends out 5.1 in compressed form through that cable. Your receiver will then decompress the audio signal into 5.1.
Um it's incredibly easy to set up. Did you try to like, set hdmi as default device?...
OK i think i get your point. However, I still have another card:Originally Posted by AMC
The standard front audio 3.5mm jack at the back of the card will not compress the audio stream. This is why we have SPDIF. If you wanted 5.1 in loseless format (not compressed) then you would have to use HDMI but I don't think you care about that.
Cheers.
