Does anyone know what the differences between these 2 are? and which one would you recommend.
According to Dremel's website, both the 3000 and the 4000 go down to 5000 RPM, the difference is in the max speed (32,000 for the 3000, 35,000 for the 4000)Originally Posted by Krahe
Hi mate, off the top off my head the 4000 has a lower rpm, think it goes down to 5000rpm where as the 3000 goes to 10000 rpm, the lower speed on the 4000 is handy if you are working with acrylic. Otherwise I dont think there is much difference, comes down to personal choice.
