What are the advantages & disadvantages when it comes to copper v nickel ? I'll be honest with you I really like the look of nickel
Thanks for that, I have heard something about copper oxidation ?Originally Posted by Bandalo
The nickel blocks are copper plated with nickel, not pure nickel. So performance-wise, they're damn near indistinguishable.
You could potentially have some corrosion issues if you used a lot of different metals in your loop (copper, aluminum, nickel, etc). Real-world you're probably not going to see it.
A few years ago there were some plating issues with the nickel blocks, but EK has resolved those as far as I know.
So go with whatever looks best in your setup.
This may be true on a micro scale, but on a normal macro scale the thermal performance difference are unmeasurable. The oxide layer and plating levels are so that they do not have any effect on cooling performance.Originally Posted by Buska103
Nickel has a lower thermal conductivity than copper... but oxidized copper has a lower thermal conductivity than nickel![]()
Performance is entirely negligible though. Copper v Nickel plated copper is all aesthetics.
I personally went for nickel for the extra 2-4$, even though my tops are all black delrin![]()
