Core Specs
384 CUDA Cores
GPU Clock: 901 MHz
Bus: PCI-E 3.01
Texture Fill Rate: 28.8 GT/s
Memory Specs
Memory Detail: 2048 MB DDR3
Memory Bit Width: 128 Bit
Memory Clock: 1782 MHz
Memory Bandwidth: 28.5 GB/sec
Key Features
NVIDIA SMX Engine
NVIDIA Adaptive Vertical Sync
NVIDIA Surround
Supports three concurrent displays; two dual-link DVI connectors, one Mini HDMI
Microsoft DirectX 11 with Direct Compute 5.0 support
NVIDIA PhysX Technology
NVIDIA 3D Vision Ready**
NVIDIA CUDA Technology
PCI Express 3.0 Support
OpenGL 4.2 Support
OpenCL Support
Core Specs
384 CUDA Cores
GPU Clock: 901 MHz
Bus: PCI-E 3.01
Memory Specs
Key Features
NVIDIA SMX Engine
NVIDIA Surround
OpenGL 4.2 Support
OpenCL Support
size and power consumption? if you notice, it doesn't require additional power cables unlike the 460.Originally Posted by 8800GT
somehow i think sticking 380 processing cores with 128bit ddr3 memory is a bit stupid...Seriously, itd be cheaper to use 336 SP's like the gtx 460, and match it with 128bit gddr5. and why would you need 2gb of low bandwidth memory? 28gbs? my radeon 1600 xt had that much when i bought it 5 years ago. Another stupid Cut down card that will be priced so you really gain nothing by going with it over a last gen, mid-tier card...such as a gtx 460 as i previously stated.
And that review kills it in my mind. $100 for that card? It looks decent on paper (save for the memory bit width), but the $100 price tag for the performance you see out of it makes it overpriced. Sell it for $75 and it's a winner, but $100 and it's a flop.
Probably 7750, due to the use of DDR3 in GT640.Originally Posted by Cannon19932006
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150612 7750 core, 110
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130795 gt 640, 110
Which you choose at that price?
They have a single slot version as well.Originally Posted by Ferrari8608
Two slots for the cooler? That's a shame. My 9400 GT has a small cooler that only takes one slot, and that's kinda what I had pictured.
Like This http://whatswithjeff.com/evga-geforce-gt-545-graphics-card/
Tapatalk'd from my HTC Merge
