Everywhere I read..I don't see any answers or all the answers are different. So I thought I'd ask myself, what are the max safe voltages and max cpu core temps for an FX 4100? Dank je!
^this 2200-2600 is the sweet spot
Sigh.. As I have already stated:Originally Posted by stryk3r1215
This is too stomach churning for me. I don't wanna screw up my system...and I already get 45-60fps playing BF3 which is all I care! When I get a SB I'll do some real OC'ing...I'm gonna play it safe and not OC![]()
EDIT: Yes, I tried the last things you guys said. I would get past BIOS menu but when going into windows it would say "Loading files" and it would reset...brought it back down to 3.6ghz and no such problem!
You are not going to be able to do higher clocks if you don't change that Power Phase Control for sure.You may also want to raise the NB speed as well while raising the voltage as it can help for stability. Get it to at least 2400 - 2600MHz with the formentioned 1.3v for testing purposes and then you can tweak it up higher once you know your CPU speed is stable. Also manually set your RAM voltage AND timings to spec.
EDIT: Also change CPU Power Phase Control to Extreme & CPU Power Duty Control to whatever the other option is. (can't think of what it's called )
My increasing the NB speed to 2400, I noticed that CPUZ was reading my pcie link width to x8, which is obviously wrong. I changed it back to auto and now it's reading it at the normal x16. And on top of that, I got a BSOD without even raising the clock. I did everything you said to do and I got a bsod that ended in 0x3D. I took off the 2400 and left it auto, and no BSOD.
Ok. Then don't raise the NB speed via multiplier. Leave the multiplier on auto and change it via FSB. Try for a combination of FSB + Multiplier which will yield you 4.2GHz & 2400MHz NB roughly. Make sure the NB speed is set to 1.3v.Originally Posted by stryk3r1215
Ok, I'll give that a shot. I changed the CPU Power Duty control to balance instead of thermal.Originally Posted by iinversion
THEN ALSO make sure those power phase options are changed or you won't get anywhere. AND make sure the RAM settings are manually entered as well as the timings.
