13,101 - 13,120 of 20,122 Posts
Cooler is definitely fine, worked as expected on the 3700X. He also repasted twice (correction, thrice) already with Kryonaut, so that shouldn't be it either. Cooler also most definitely doesn't have a plastic foil on it. Fans etc are running plus one CR20 run shouldn't saturate the water either.
I don't know then. Sounds like it's overheating not drawing down temps fast enough and then throttling downwards.
That said he can try a few things and even use the 1usmus Power Plan (works for Zen3 just fine):
  • Global C-state Control = Enabled
  • Power Supply Idle Control = Low Current Idle
  • CPPC = Enabled
  • CPPC Preferred Cores = Enabled
  • AMD Cool'n'Quiet = Enabled
  • PPC Adjustment = PState 0
Leave CPB on. Put PBO on Manual, use Motherboard/Auto Limits, use a low offset like +100mhz, and then go into Curve Optimizer to undervolt it, say -15 to all cores as a starting point and see what that takes it.
Yeah then grab a DAC it is.
I really like my Modi 3+ + Magni and combo though it'll be $200 total. Headphone only though if that's a dealbreaker (I use an USB Mic myself so I don't need an Mic-in jack). If you wanted an cheaper all-in-one DAC/AMP unit with microphone and headphone jack for a good price that has good sound quality, Fulla is quite nice for $99 Schiit Audio: Audio Products Designed and Built in California and a very good budget option. If you want a n even more budget option: Monolith by Monoprice USB DAC - Monoprice.com but I'd rather just spring for the Fulla at that point unless you need the tiny footprint.
Not sure how shipping to EU is.
Depends on audiophile you want to get though, I'm sure you could find some $20 things.
Anything else you could suggest? So that I have more choices to look for
also this is how my cable management looks like because of ducking Silverstone RL06. Can’t place them all behind mobo on the other side :( but at least it looks cool with all RGB on :D
2468692
2468693
Not really, i'm not an expert at all on the stuff, just what I have and know people who've had. It really depends on how deep down the audiophile rabbet hole you wanted to go down and/or if you NEED a mic-in jack or just headphone-out jack, if you wanted an all-in-one unit or a separate DAC/AMP, and what your budget is. I would google Reddit posts, like this kind of stuff Reddit posts about DACs and AMPS.
Looks nice and clean. Mine is an absolute disaster but hey it's out of sight, out of mind.
Thank you for everything. I’m looking for headphone only DAC/AMP. I have USB mic with its own soundcard and settings.
Good luck! It's nice to have a good one anyways.
You're probably sick of this, but could you run ZenTimings and paste the result? ZenTimings
I was doing some Googling and it looks like all the stuff I could find was stuff you already tried (i.e. turning PCIE to Gen3) so that's not h. And did you try turning of Spread Spectrum Control?
2468706
There we go
Spread Spectrum Control?Haven't heard of it, so probably haven't tried.
There we go
It's under Tweaker Tab, just below CPU Clock Frequency at the top. I doubt it will fix anything though, the only thing it does is disable some noise in the clock, was just curious.
Uhhh what the... something seems VERY broke there. Why is that coming up with NaN and infinity on the clocks? 1.25V on CCD? 40V on IOD?? Is it running as an Administrator? It should look like this:
2468707
Very not looking right. What if you select #1 at the bottom?
Do you have a Trusted Platform Module or something running in the BIOS?
Don't have #1, only two #0s
Okay. This explains why changing XMP did nothing to sound. Feels like my IF doesn't exist.
Oh boy, i guess its time for another troubleshooting!
Huh okay, I guess that looks fine actually. Well if you got the time on your hands, I could say the very last thing to try would be
Tweaker:
  • Turn off Spread Spectrum
  • Set CPU Clock to 100.00
  • At the very bottom there's a button to set Loadline Calibration, try setting both CPU/VSOC LLC to Normal, or set them both to High.
--> Try that first. See if it does anything
Then:
  • Turn off XMP
  • Set Memory Multiplier to 36.00
  • DRAM Voltage 1.35V
  • under Advanced Memory Settings set:
  • TCL 16
  • tRCDWD/tRCDR/tRP = 20
  • TRAS = 40
  • tCWL = 16
  • Leave all secondary on Auto
  • Command Rate 1T
  • ProcODT 53
  • RTT_NOM Disabled
  • RTT_WR Disabled
  • RTT_Park RZQ/5
Settings - AMD OC Menu:
  • DDR Frequency -> Set Memory to Manual -> Memory Clock 1800
  • Infinity Fabric Frequency - Set Manual to 1800
I think you've already got VSOC and stuff set as before so those seem fine
See if that does anything at all. If it does you can try Manual Timing the rest of them:
2468713
Overall though I think it's just a bunk sound controller.
Tweaker:
Then:
  • Turn off XMP
  • TCL 16
  • TRAS = 40
  • tCWL = 16
  • Command Rate 1T
  • ProcODT 53
  • RTT_NOM Disabled
  • RTT_WR Disabled
  • RTT_Park RZQ/5
2468715
Are these the right timings? RCDR and RCDW especially because everything looks complicated to me ahahah
Tweaker:
Then:
  • Turn off XMP
  • TCL 16
  • TRAS = 40
  • tCWL = 16
  • Command Rate 1T
  • ProcODT 53
  • RTT_NOM Disabled
  • RTT_WR Disabled
  • RTT_Park RZQ/5
2468717
This is how it looks now after all those settings tuned.
Sound issues are still there. I will order FX-Audio DAC-X6 tomorrow to have better soundcard than what I currently have...
welp, been running F31o for a few days now.
Now if AMD could just design a power plan that doesnt have the CPU sawtooth temps, then I wouldnt have to run a custom plan anymore.
Hm. Did we do something with CPU? It runs 5C hotter (around 70C) than my usual (65C) under heavy load.
Not that I can think of, most of it had to do with DRAM. CCD provides some more voltage to the controller but I'm not sure it would have much of an impact. Since none of it fixed the problem anyways, feel free just to do a BIOS reset to defaults.
Also don't forget these settings under Tweaker -> Advanced CPU Settings are generally recommended all around. Maybe they got reset:
  • CPPC = Enabled
edit: Maybe maybe the changes to Loadline Calibration. Could turn those back to Auto since it didn't fix the problem.
  • CPPC = Enabled
Alright. I’ll set it up.
got a question - that BIOS image you provided - F31j - my MoBo says it’s invalid :( got another version to download?
