What this is for:
This guide is intended to make high performance overclocks easier to daily drive. You'll be able to max out your processor's performance easily, while retaining the convenience of the dynamic clocking provided by the SMU. You can not set a fixed frequency, but this will allow you to easily pick a point in the SMU's performance and voltage table and set it as your default performance target. The SMU will operate around this performance target, and will abide by normal safety limits unless you manipulate or disable them. If you are attempting to break a world record and/or set static clocks, this may assist you, but there may be easier ways to achieve that. This guide is not focused on that.
This is where it all started, and the work that got me to this is detailed in this post...
Using Ohm's Law power equation for overclocking
I continued with this and discovered the math behind the SMU's Dynamic Voltage Table (DVT), how it is calculated, and how to set it for a specific performance target. This is for Zen 2 (3000's) and Zen 3 (5000's). I am old school and I do not like using software to overclock, and when I purchase an unlocked processor, I want it actually unlocked. All of this can be done in the BIOS.
How to set a specific performance target:
This guide is written around how to do it with an Asus motherboard, however, as long as you have cTDP, PPL and PBO, you will be able to do this and it is not manufacturer specific.
To get started, you will need a "K" value which is your performance target and with this K value you can easily calculate this. You need Cinebench R23 to get this value along with HWinfo.
In your BIOS, set PBO Manual with scalar X1 or X2 and PPT/TDC/EDC as Auto. This works with or without Fmax enhancer as it does something similar, but isn't adjustable. For this purpose, the only value it has is getting rid of EDC. Leave it off and keep EDC if you choose. Voltage needs to be set to auto along with LLC with no offsets. Your memory OC needs to be already done before you start. Make sure "performance Enhancer" is set to default, not Auto.
Now, let's get your K value...
To get your K, start cinebench and run a multicore bench and while it is loading, bring HWinfo to the foreground. Reset the timer as the render window goes black and watch HWinfo. When you get to your MAXIMUM clocks on your cores and/or your thermal target (this can be whatever, I chose 70*C for the screenshots) note your current PPT and core voltage at CPU TFN2 as you'll need these. The PPT in watts is going to be your performance target/TDP target and the reading at CPU TFN2 is the voltage we need to base your TDC calculation on. This give us a specific "point" on the voltage table that is unique to your silicon. All of this can be adjusted to your needs, and I'll get to that later.
Take your Voltage you noted in CBR23 and do " PPTw / Vcore = TDC ". This your new TDC value you'll enter in PBO. For example, I had " 150w / 1.344v = 111.6A " so my TDC became 112A.
Reboot and go back into your BIOS and hop over to AMD CBS/NBIO/SMU and set cTDP to manual. Put the PPT you noted in CBR23 there, mine was 150w. Scroll down to Package Power limit and set that to manual. I recommend you set this to 40 watts above your cTDP maximum, and the minimum you can set this is the same as cTDP. Do not set PPL less than the cTDP you just entered.
Now while still in the BIOS, go to PBO and set PPT to what you set as PPL in AMD CBS, and set TDC to the value you calculated earlier. Set EDC to your motherboard VRM limit (or don't worry about it if it is disabled). Set the bios options that reduce latency and turn off power savers that I detailed in the post linked above. This is optional, but there is a lot on the table if you do so.
That's it. It's that simple. This moves your processor power target to the cTDP you entered and the effective requested VID to the voltage you used to calculate your TDC. If there is a variance, continue reading as I get to that a little further down.
To give you an example, I am running these numbers right now...
Example:
TDC = 112
PPT = 190
EDC = Set to board VRM limit (mine is 247)
cTDP = 150 (which brings me around the Zen2's 70*c soft thermal throttle)
PPL = 190
The SMU uses TDC and cTDP to calculate what voltage to use. In my example, full load @ 150 watt TDP the SMU will request 1.344v to get maximum clock speed. 1.344v is my new p0 VID maximum.
Depending on your board and/or bios, there will be a variance. After everything is set, if you change Vcore from "Auto" to "Offset +/- 0.006v" it should take care of the variance. My variance brought my voltage slightly low, so I had better results with +0.006v offset. You'll need to watch HWinfo under CBR23 to determine whether you need to correct + or -. So far, I know this variance is caused by at least 2 things. The first is manufacturer programmed voltage offset in the BIOS and the other is power reporting deviation. Regardless, you'll be very close first try if you did the math correctly.
How to customize this to fit your needs:
Let's say 1.344v makes you uncomfortable at full load, and you would feel better with 1.300v. You can calculate " cTDP / 1.3v = TDC ". Your new max VID for that state will now be 1.3v at max TDP @ max sustained frequency. To be clear, the SMU will still choose a lower voltage if it feels it is appropriate for the given load, your choice on voltage to calculate TDC sets its upper limit.
The SMU will not exceed defined operating limits unless you disable or modify them. If you where to set the voltage to something outside the SMU operating limitations, it would simply not use it and you will have a significant performance reduction. Adjusting the full load voltage with the TDC calculation is very useful in fact, just be aware it has limitations and test it if you deviated from the base equation to set a lower voltage. The same also applies to higher voltages. The bottom line is, deviating from the base calculation here is very useful for fine adjustment, and may not be suitable for larger ones. I suggest using "Max voltage offset" setting in AMD CBS/NBIO/SMU or using the standard voltage offset setting provided by your motherboard manufacturer for larger adjustments. Large adjustments to voltage using this method can throw the equation off and you'll spend more time fixing voltage variance. If you are okay with that, then go right ahead.
This process can also be helpful to DECREASE your processors power target for quiet computing or HTPC applications. You keep all the safety, have full control of the SMU performance target and you can retain the dynamic clocks. It's everything I think any Ryzen owner ever wanted instead of hoping you hit the magic PBO scalar. Below is a quick list of the equations used for reference so you don't have to dig through the information in the event you need to reference them again.
Quick reference equations:
V * A = W
W / V = A
W / A = V
TDC = Desired TDP / Desired Max Voltage
cTDP = Desired max power @ temp / Desired Max Voltage
PPT/PPL = CPUw + SoCw + MemC + *headroom (if desired - Minimum PPT/PPL is cTDP)
special notes
1.) If you use extreme loads such as Prime95 on a regular basis, I would recommend using it for your K value instead of CBR23. I chose CBR23 as it is a proper full load and "real world" and not extreme. CBR23 is probably the highest load 90% of processors ever see. Choose what fits your specific worst case. The SMU will not remove any defined limits unless you change or remove them, nor will it exceed/boost beyond the specified performance target.
This guide will be updated with additional information as it is available. I am currently testing ways to quickly correct for deviation.
If anyone has questions or needs clarification, please let me know!
Example:
TDC = 112
PPT = 190
PPL = 190
V * A = W
W / V = A
W / A = V
special notes
