I overclocked my HD5570 through ATI OVERDRIVE to the maximum that that software allows. I know msi afterburner would do more.
My temps have gone down 10c since even though I have overclocked to the max for this card of 700MHz clock and 950MHz mem (sapphire ddr3).
I did played with enabling manual fan control but it is currently off.
My normal GPU temp has gone from 56 to 41c. AMD OVERDRIVE shows the same reading.
Can I trust these readings?
As a first time builder, should I overclock my cpu (phenomIIx2 545 3.0GHz) or with such a low end graphics card or would there be no point?
