Originally Posted by
djriful
That's weird. Well let's put it this way.
Are you going to store small files up to 200mb per file? Seeking time would be more important then pick 7400RPM with USB2.
If you are going to transfer and store 1GB+ files... take USB3. It requires little seek time but better transfer rate.
What I would do?
Grab the USB3 and swap in an SSD.
Err... 200MB is huge. "Small files" would be stuff under 512KB.
Google used a 4MB read/write size on their filesystem - but I gather they used to run 4-drive RAID 0+1. (maybe they still do) That means 2MB reads/writes per drive is the level that they chose for optimal performance. Later they apparently reduced it to 1MB to improve responsiveness of their services. Clearly they feel drives can handle that much seeking while maintaining high performance levels.
In this case, either option is fine, because even 50mbit Blu-Ray rips only consume about 6MB/sec, which is well within USB2's speeds. But that said, I'd go for the USB3 external. I'd rather have the high transfer speeds when doing large file copies. That's the reason I got a USB3 flashdrive.
fofamit
Well it does depend on a couple of factors, basically it mainly boils down to the quality of the external drive itself. I have seen some external USB 2.0 drives have a write speed of around 30MBps (which is amazing), while I have seen many others which have around 10-15MBps.
With that in mind an internal 5400RPM drive will have more than a 30MBps write speed, so your bottleneck would probably be limited to USB 2.0. So I would say go for the USB 3.0 Drive.
My Hitachi 2TB had read/write speeds of 34MB/sec.
But I still liberated it from its enclosure. Now it's my Steam games drive... sequential maxes at 155MB/sec.
mingqi53
Sean Webster
Id grab the USB 3 drive, far more bandwidth.
You can easily hit the max speeds of the usb 3 HDD, but the usb 2 hdd will be limited to ~25-30MB/s in real life use
Would playback of 1080p HD videos suffer from the 5400 RPM? Or would only seeking be affected? (Relative to a 7400 RPM)
Only seeking would be affected. It might take 10ms longer.
Keep in mind that low RPM drives are the ideal medium for video. That's why most security camera and surveillance devices use AV-GP drives. Low RPM, very little error correction - they just keep dumping data onto the platters at a stable rate.
Sean Webster
I have a few 5400rpm spinpoint f4 2TB drives and they run multiple 1080P steams fine b/w my father and I. Seek speeds on them are only
very slightly slower than my F3s.
I played 15 video streams simultaneously off a ReadyNAS NV+ (usually caps out around 20-25MB/sec, very close to USB2's limit) - I have no idea how many 1080p streams I could play, but I think in my case my videocard (GTS 250) was holding me back - not my drives.
