I've been told in the past that CPU overclocking doesn't cause artifacts, only GPU overclocking, but apparently not. I just got a Pentium D 805 and found my maximum stable overclock to be 3.24GHz on my current motherboard (it only allows up to a .03 increase in voltage so I can't get any higher). If I run any higher than 3.24, I get artifacts in all 3D applications except for the DXdiag Direct3D tests, and the artifacts become more severe the higher I overclock (system is bootable up to 3.44GHz).
Graphics settings were a stock while I was finding the max CPU overclock, so it wasn't a factor as I now have both overclocked and no artifacts. Just a headsup for people experiencing artifacts if they want to check their CPU settings if all else fails.
