I've been trying to OC my i5-4690K with Darkwizzie's guide and the Yet Another Haswell Guide on /r/overclocking. Currently I'm at a multiplier of 45 on a Vcore@1.4V. Temps under load during the x264 stress test is at most 79C. Under these settings I can not complete a single loop of the x264 test; however, I can complete Cinebench, a POV-ray rendering, and play games. I'm trying to get it stable during the x264 stress test. These are the things I've tried.
Lastly, the VIDs of the cores seem to be rock solid under load, so that's good. If I can't get it stable under x264, I might just stick with this multiplier anyway if it doesn't crash in my day to day usage. Or if you have a method or stress test that I can get more consistent results from so I can more accurately see how may changes are affecting the stability, that would also be appreciated. Thanks in advance.
- Tried Vcore all the way up to 1.45V with behavior set to override
- Tried VCCIN @ auto, 2.0 and 2.1V
- Varied Uncore ratio from 33 to 39. The stock for my board is actually 38, which seems high from what I've read online.
- Set Vring to auto and 1.2 override
- Set IO voltages to +/- 0.1V
- Set Sa volteage to + 0.1V
