high mhz ram or low latency?
5.4K views 19 replies 10 participants last post by  Timlander
#1 ·
im trying to figure out if i should get 2133 ddr3 cas 9 or ddr3 1600 cas 6 which performs better
#3 ·
Is your system Intel-based or AMD-Based?
Intels like Higher Frequencies better than Low Latency
AMDs work the opposite way
Post your System Info so we can get a better understanding of your rig
#4 ·
Intel chips like higher frequencies better.
That being said, what are you plugging the RAM into? To get 2133mHz on say a Bloomfield 1366/X58 setup you'll need a STUPID high QPI/DRAM voltage that you'll not want to run 24/7 if you value your hardware. 1.4-1.5V+ thereabouts
I run my 2133 RAM at 1866 for the lower voltage.
#6 ·
Originally Posted by millsc;12123804
im building a p67 based system 2600k i have a extreme 4 asrock board gtx 570 now trying to figure out memory
You should be better with high frequencies, Check the voltage though
#8 ·
#10 ·
#17 ·
im gonna go with low latency 1600s then seems like good results achieved
i bought my set for its looks (black on black
the thing is ram doesnt really improve much of ur performance as long as u have 1600mhz. So imo if u r on a budget find something cheap and if not find something that look nice
#19 ·
If your ocing your chip to its max, get some better mem. If your doing light ocing, any mem would do since the gain is negligible and really seen in benchies.
Best mem for the price is the G.Skill PIE ( 7-8-7-24- 1T( default is 2T but I run it at 1T) If you don't know what the T is, the same thing as taking that first 7 and turning it into a 6. So effectively I run mine at 6-8-7-24.
http://www.newegg.com/Product/Produc...-335-_-Product Look up reviews, they are great at being ran aggressively and very cool.
#20 ·
This. With DDR3 especially go with tighter timings if you have an amd system.
