[HWC] Coolermaster Hyper 212+ Review
5.9K views 53 replies 31 participants last post by  gian84
#1 ·
It certainly has been a long, long time since we looked at HDT (Heatpipe Direct Touch) based cooling solutions. The last one we looked at was from OCZ and was essentially a tweaked clone of the Xigmatek S1284. Since then, many air coolers have come and gone…but one thing has remained constant: the three HDTs we have reviewed are still near the top of our charts and are easily some of the best bang for the buck coolers out there. Today we look at another HDT-based solution, one that is poised to upset the Xigmatek / OCZ apple cart and bring in a new reigning king of the budget coolers. The heatsink we are talking about is the brand new Cooler Master Hyper 212 Plus. While a relative new comer to this whole HDT game, Cooler Master is not new to the Air Cooling arena.
Continued...
Looks like there is a new leader in value HDT coolers.
http://www.hardwarecanucks.com/forum...er-review.html
#2 ·
WOW
Those test results blew my mind. That cooler is like a HDT TRUE but better!!! I am speechless other than the fact that you can hear me mumbling as I count the money in my wallet to see if I have enough to go pick one of these up soon.
#6 ·
Originally Posted by sodaholic134
Awesome results. Guess my trusty ol' Xigmatek S1283 is still the bang for the buck leader.
I'll probably pick this up because it can officially have two fans, plus the extra heat pipe.
It is for HDT but Mugen 2 is better than s1283 bang for buck overall
#14 ·
Originally Posted by T3h_Ch33z_Muncha
wish they'd made the pipes 8mm instead of 6mm - that would have made much more of a difference especially on the Q6600.
It's not the amount of pipes but how the pipes are aligned.
Instead of lining the pipes perpendicular to the fan line the pipes in parallel to the fan therefore each pipe gets equal cooling from the fan.
#15 ·
Can you show me an example of a cpu fan with heat pipes perpendicular to the fan?
#16 ·
i didn't say anything about the amount, i said the pipes should have been 8mm. If you look at the article and see the pic of the base there is a lot of aluminium there that could easily have been replaced with wider heatpipes.
#18 ·
I not good at drawing so please excuse me. See attached pic.
Imagine your looking at the tower cooler from the top.
Red dots = heatpipes
Green = CPU fan
Arrows = Direction the fan is blowing
Most tower coolers are designed like the one on the left. With the heatpipes perpendicular to the fan.
I would like to see a tower cooler design with headpipes that are parallel with the fan like the picture on the right.
My bad, I meant to say thickness.
Yeah I don't know why they designed the base like that. I understand how the pipes go in direct contact with the CPU but wouldn't there be higher chance of air pockets with this design compared to a uniform flat base?
#19 ·
Green = CPU fan
THIS is what I thought you were saying when you say "perpendicular":
#22 ·
I love my Hyper 212 <3!!
4GHz overclock with 47C load temps? Who wouldn't love that?
I have the original 212, not the 212+, which the 212 seems to be better. Mainly because of the two separate pieces, so that the heat is dissipated out and the heat moves away from the unit quicker. Just my $.02..
Also, I got the original as said, and the new one has this flippy thing to change between sockets. Mine came with 3 (?) separate pieces for LGA775 and AM3/AM2
My original also seems to cover a bigger area range. More real estate = more cooling.
What's nice about this though is the direct-touch heatpipes on the CPU, which the original didn't have. So I guess for what the new pluses lack, this makes up for. Probably right on par -- or, just above even because of that simple fact.
#25 ·
Well, most HDT coolers (judging by my S1283 and S963
) have a bit of a gap between the aluminium and the copper.
This serves two purposes:
1: to force air bubbles into instead of between the pipes+IHS.
2: to force excess TIM into instead of between the pipes+IHS.
The second is why i adore the design of HDT coolers so much - it can be engineered so that only the optimal amount of TIM is between the CPU IHS and the heatpipes.
#26 ·
While it does come out swinging and does continue to keep swinging even with the speed dial set to 11, in the end the 212 PLUS was edged out by the Prolimatech&#8230;which was also paired with a slower
I think, that I'll keep at the Prolimatech. Though nonetheless, I agree that this is quite the performance.
