I put a PTM7950 and cheap thermal pads on my RTX4090 Strix OC White and this is what happened
1.2K views 9 replies 4 participants last post by  oc_og
#1 ·
Hello everyone,
I've recently replaced the thermal pads on my NVIDIA RTX 4090 Strix OC White and also applied PTM7950 instead of traditional thermal paste. I'm checking if the temperatures I'm seeing are within normal ranges. My current setup and results are as follows:
Setup:
  • GPU: NVIDIA RTX 4090 Strix OC White
  • Thermal Interface: New thermal pads + PTM7950
  • Ambient temperature: ~22°C
  • Case: Open side panel
Temperature Results (after ~10 minutes of sustained load):
Cyberpunk 2077 (highest settings, 7680x2160, ~70fps):
  • GPU Temp: 65°C
  • Memory Temp: 68°C
  • Hotspot Temp: 78°C
  • Power Draw: ~430W
Furmark Stress Test (highest settings, 7680x2160, power limit 120%, ~200fps):
  • GPU Temp: 72°C
  • Memory Temp: 65°C
  • Hotspot Temp: 88°C
  • Power Draw: ~580W
Idle Temperatures (~10 minutes after Furmark):
  • GPU Temp: 42°C
  • Memory Temp: 48°C
  • Hotspot Temp: 50°C
Are these temperatures fine, or should I be concerned about anything? Any feedback or comparative experiences would be greatly appreciated!
Thanks!
Create a forum post. I want to know if these temperature measurements are fine I replaced thermal pads on an NVIDIA 4090 Strix OC White Temperatures I get in OC mode Cyberpunk, highest settings, resolution 7.680x2.160, ~70fps, power draw: ~430 watts, GPU temp: 65, memory temp: 68, hotspot temp: 78 Furmark, highest settings, resolution 7.680x2.160, power limit 120%, ~200fps, power draw: ~580 wattws, GPU temp: 72, memory temp: 65, hotspot temp: 88 I also placed a PTM7950 instead of thermal paste Ambient temperature 22 degrees, PC case open
mention that I did ~10 minutes of sustained load before measurement
Idle temperatures around 10 minutes after furmark: GPU 42, memory: 48, hotspot: 50
#2 ·
Your thermal pads might be a little fat making a little loose on die contact. Hotspot delta looks really good. Either that or not enough flow from pump or need more rad
My 4090 on ambient waterblock will get to 51-52c at 450 watts but as soon as load is off it drops down to usualy 24-28c depending on my small room temp which can get pretty warm sometimes lol
#3 ·
I removed the water block, with the water block I got perfect temps, lower 40 degrees under full load
Now I went back to stock air cooler (cause I want to sell it) but I used 1.5mm on the VRAM, very soft pads (the Aairhut) but I am not sure if them not compressing properly is causing this issue or maybe its not an issue at all?
Really not sure about this... and whether to reopen and reassemble it, a buyer might be frustrated having these temps
@Gamerman what thermal pads do you use?
#4 ·
did you replace the thermal pads with the same thickness that came with the block?
some parts can use thicker pads than others so you have to double check.
also i havent had a chance to try myself yet but ptm7950 requires break in a few cycles supposedly
#6 ·
Use Gelid GP-Extreme 1.5mm thermal pads. They are super soft and squishy and will compress fully to allow full contact with your GPU core. Plus they perform really well, the go-to pads a long time now.
DON'T use the Ultimate, they are quite hard and don't compress, and you'll lose contact with the GPU core.
Oh, Kritical pads are really good as well.
And I just checked, Kritical has 1.25mm pads. :)
#8 ·
It's really interesting I replaced the thermal pads on VRM etc. with Arctic TP-3, put thermal putty on the VRAM, and some (probably fake) PTM7950 on the GPU itself
Now I get these values
furmark (after 10 minutes, avg): GPU 67 / MemJ 66 / Hot Spot 77 / Power 560 watts
cyberpunk (also after 10 minutes): GPU 60 / MemJ 67 / Hot Spot 69 / Power 426 watts
Yesterday in the evening the values were much worse, GPU in the seventies, hotspot in the eighties, but today it seems to be better... I really double-checked, the average power consumption definitely is what it was on my first tests, not sure why that is
And also not sure why it's generally so much better now, but I'm happy with it... Maybe it's because I put so much thermal putty that it probably went a bit further on the board than just the VRAM
#9 ·
You took the blue thermal pad plastic off, right?
This post has been deleted
