Hi everyone, I appreciate you for taking the time to contribute to this topic.
I've had spent dozens of hours trying to diagnose and fix the problems that my pc has with the overclock, until now that I am so frustrated and out of hope that I am reaching out to you all that are far more experienced in such field and hoping that with your help I will manage to resolve my issues.
For weeks I’ve had problems with overclocking, no matter what setting I turn on or off/increment or decrement, I am unable to reach a stable overclock that wouldn’t result in system freeze or sometimes a BSOD. (Usually my system just freezes and the only thing I can do is shut down the pc by holding the power button for few secs. Second or so before the system freeze, there’s always this single static electric click noise which is followed by whole system freeze.)
In fact, I am starting to wonder whether there is a hardware issue like PSU failing to supply enough power to CPU or motherboard having some kind of defect that causes this. Unable to investigate this as I do not possess a backup psu, nor motherboard.
My Setup;
CPU: I5-8600k
MOBO: MSI Z370-A Pro
RAM: Kingston Hyperx Predator DDR4 3000MHz
PSU: EVGA 600W W1 80+
GPU: Asus Strix GTX 970
Heatsink: Cooler Master Hyper 212 Evo
Is there anything that I am missing or have configured incorrectly? Anyone with same setup mind sharing their OC? I am open to your suggestions and willing to cooperate with you. Could the PSU be the problem as it is old and classified as low-tier?
With these exact settings I was able to run prime95 for 9 whole hours, the next day the very same settings were failing, resulting in system freezes. I have tried increasing and decreasing Vcore but that doesn't seem to help. Any ideas what could cause this?
I have attached images of my current OC settings.
My Setup;
CPU: I5-8600k
