181 - 200 of 298 Posts
Are we able to run power limits above +50 safely on these cards? or does it even work?
Answer : yes it seems to work must have been another setting that caused me to not be able last night.
My liquid devil after some testing with MPT last night was hitting right around 2250mhz core 950 memory - set at 2300mhz 1325mv - 950 mem with a bowed upwards power curve "1550mhz-1094mv"
update: Up around 2270 mhz moving power limit up to +75/+80.
when i changed my mhz max above 2300 i was seeing the core jump to 2350mhz in the limited failed tests i seen not sure why it was just doing 50mhz leaps all the sudden but i assume its running into a voltage / power limit because the test become unstable there quickly.
update: Assuming this is still going to happen haven't found it stable when trying to push past 2325 in wattman
Is it just me or does Wattman and MorePowerTool adjust core freq diffrently? in Wattman I set the volt to 1050mv and Core freq to 2000mhz on my RX 5700 XT and i get 5200p in Superposition.
If i set the Core voltage to 1050mv and core freq to 2000mhz in MorePowerTool i get only 4900p in the same test... You can change the GFX Core Freq and your overall max core Freq in MorePowerTool, is that the diffrence then?
i notice that 20.2.1 driver require more( ~0.04v) vcore for the same clocks to be stable compared to previous drivers.
anyone else with the same issue?
I noticed that the MPT voltage upper limit appears to be fixed at 1350mv. Is this a MPT limit or driven by something else?
It doesnt work for me, I get this error message when trying to create the bios file with this software. Also the Vram settings is blanced out, maby that is correct?
I use a bios file created with GPU-Z as intended and use a .MPT file where i only changed the Core Voltage from 1200mv to 1115mv. Nothing else is touched.
Wouldn't it be nice if you could decode/encode the timings?
Or inject them directly! /forum/images/smilies/redface.gif
/forum/images/smilies/wink.gif
Ok well I'm not really into this that much so yea I'm a noob.. :p but it would be really nice if I could get this software to work.. from my understanding the Vram tab is optional?
Someone who have succeeded with this tool? What I understand the error message I get is because I dont have anything filled in under the VRAM Timings tab.. But how do I get the information to fill in there?
Eliovp, you show i picture of timings and hex values for those I guess? how do we get those?
Thanks for the tool, saves me a job lol!
Doesn't let me save the file after copy/paste memory straps. Tried running as Administrator but same error.:
How do we lower the MVDDC with this? I'm new to AMD Cards so probably just overlooking something...
Well, seems like vram_module is not read out properly. For some reason..
The other error message.. i will also look into that.
Never appeared for the beta testers.. so i am sorry, never had a navi card. ;)
Never appeared for the beta testers.. so i am sorry, never had a navi card. /forum/images/smilies/wink.gif
First off, Thank you for your help.
Ah ok so Vram tab should be filled out automatically?
This is the card i have: https://www.techpowerup.com/vgabios/214475/gigabyte-rx5700xt-8192-190909
Maby it doesnt work?
I have attatched my bios file and my .mpt file if it helps.
