Originally Posted by
Shadow11377
1366x768 is marketed as 720p HD but it's far from 720p. It's just 720p "Capable" I would not call that HD, personally because It's an awful resolution to have. It's just enough scaling to degrade the video quality of a nicely rendered 1280x720 video or image.
I'd rather have a 1280x720 monitor because it is a standard resolution and 720p content won't be stretched on it.
This is a screenshot taken from Portal 2 at maximum settings at a true 720p (1280x720) image saved in a lossless format.
This is the same image, scaled to 1366x768 in GIMP, look at the difference in quality, it's due to scaling at a fraction instead of a whole number.
This is the same image, scaled to 2560x1440 in GIMP, this did not lose any quality because it was scaled exactly by 2, which is a whole number. This means for every pixel, there are 4 of the same ones. It's a direct size increase while not adding/removing pixels selectively. You can open this in MS Paint and stretch it to 50% H+W and get the exact image you saw first, you can not scale down the 1366x768 one back to the original because it's added pixels to make up for it not being regularly scaled.
768p Televisions are one of the reasons why consoles look much worse than PCs in terms of graphics, the graphics are not always a native 720p so they're scaled to 1280x720, then when it's sent to the TV the TV Scaled it
AGAIN from 1280x720 -> 1366x768 doubling the degradation of quality as seen in my pictures above. I'd strongly recommend you don't purchase one if that is your reason for asking this question.
It should be labeled on it somewhere. If you can't see it, then check for the model number and post it here or google it yourself.
