Is there a big difference between a 2666mhz and 3600mhz?
7K views 25 replies 13 participants last post by  Stealth3si
#1 · (Edited)
I know higher speed number is always better but I want to know how much of a noticeable difference is there between 2666mhz ram and 3600mhz ram on an i9 9900k and Gigabyte Z390 Aorus Ultra. I will be gaming and general productivity. FYI, the difference in price between the two "identical" sets I'm looking at getting is $150. One set is 18-18-18-43 1.20V while the other set is 18-22-22-42 1.35V. How much of a difference in performance speed would I be missing out in games and general productivity if I went with the cheaper set? Thank you for your help!
#2 ·
Why not get something in between like a 3200 MHz kit?
#3 ·
Yea, you know what? I think I'm getting a 3200 Mhz kit from OLOy OWL. Price is between the two and the performance is better than both it seems.
#4 ·
According to your sig you got some 3200 cl14. Why not add another kit
#13 ·
bc I'm getting 128gb
#14 ·
well the one with 18-18-18-43 1.20V is 2666mhz so yea you are right, it's pretty bad. Hence why I went for the owl
#15 ·
Not sure I understand your question.
#9 ·
😂🤣 Nope wrong sr Bdie will slap around dr anything other than possibly djr or super binned rev e which do 5000+
#18 ·
In my case, I've never seen any improvement due to faster ram. Where I've seen improvements is with More Ram as even at 2133, it's still faster then any drive (rust/ssd) offers in bandwidth.
What I need is maximum ram so although I'd love to go with a faster memory, I'm going with 3200 as it's the best bang for buck right now and 4x 32GB sticks since I'm currently running 64gb.
#21 ·
update report so I got the 2666 set and overclocked it to 3067mhz at 16 18 18 38 stable
I tried out a new set of owl oloy 3200 16 20 20 38 and it was unstable at advertised settings
#22 · (Edited)
With 32 Gb x 4 you will likely struggle to stabilize 3600 anyway. Likely why the 3200 wouldn't work.
With that much ram and current costs, I wouldn't advise in spending that much just to go to 3600, you should just stick with the current ram until you are ready to move onto DDR5.
From what I recall, 2666 kits didn't really scale to high, I had a 2x16 2666 ballistix kit that could only manage 3000CL14 before my current kits.
What do you actually use 128 Gb for anyway? And which motherboard do you have < motherboard is very important for ram overclocking.
I'm going to take a guess and think you are running on a Gigabyte Auros Z390? These boards cannot even stabilize 2x16 3200 CL16, I know because I tried.
Oh right there we go, its in your sig after I clicked on the arrow. You will not 3200+ on a Gigabyte Auros Z390 / Z370 no matter what you try.
#23 ·
I just have a lot of things open at the same time is all. Mostly its a game with a lot of plugins and mods tho with poor coding and memory leaking since the developers refuse to support 3rd party software that I use along side the game, Nothing I can do ab really other than get more ram, which now allows me a much smoother experience playing the game hours at a time, even tho technically performance is worse. as for the mobo, this is not the exact same situation as you but prev I had a stable 4x8gb 3200 CL16 on the same mobo I have now.
