Issue with QCK Heavy. Test your own mousepads for inconsistency.
5.4K views 15 replies 9 participants last post by  qsxcv
#1 ·
Hey everyone!
So basically the thing i've noticed with the Qck Heavy is that it's smoothness is inconsistent across the x-axis and y-axis.
Swipe a finger across the mousepad left to right and it's smooth. Run your finger/mouse up and down the mousepad and it's much rougher.
This creates an inconsistency in game. As a competitve cs:go player, this varying resistance is something i notice when swiping my mouse across the pad to flick to targets and while pulling down to control spraying.
Do this test on your own mousepads and let's see if there are other soft mats that have this problem.
I'm looking for a mousepad which has a consistent pattern with equal resistance in every direction.
#8 ·
Originally Posted by Kitzstyle View Post
sorry, if you cant handle this slight variation in a cloth mousepad, which is normal, i dont really see how you could call yourself a competetive gamer.
But if you really want a mousepad without variations, you need to look for hard plastic maths. Like 9HD from Steelseries.
What im saying is that it's not optimal (for me at least). I play CS:GO as Global Elite and have also played CS:Source with top pros. Any inconsistency in muscle memory is bad in my opinion.
#10 ·
As someone who played professionally, this is not a real issue. You realize that a lot of sponsored players just use whatever they are told to. Also I dont think any cloth pad will have a consistent X and Y friction because of how they are woven, you would need to buy a mousepad of another material, like plastic, to achieve even friction.
#12 ·
would i be wrong to say that
1. all cloth is faster/smoother in one direction anyway
2. for mousepads it would only make sense to align that direction horizontally or vertically; otherwise moving the mouse "northeast" would be different from moving the mouse "northwest".
3. in general horizontal movement happens more than vertical movement
4. thus for most cloth pads the fast direction of the cloth is aligned horizontally
#13 ·
Certainly there's a difference moving the mouse from left to right, moving it up-left or down right, and moving it up and down.
The more vertical the movement the more resistance. The more horizontal the movement the smoother/faster it is. It's annoying!
So yes, it's the horizontal direction that is faster and i'd guess it's the same on other mouse mats that have varying resistance.
Why should it be impossible to find a mouse mat that has a weave/pattern which is evenly smooth vertical and horizontal?
#15 ·
It is impossible because any sort of cloth that would be used for this doesn't work that way. $10k racing bikes, made of carbon fiber, have to use multiple "sheets" to accommodate the directional differences in the material. For a $5 manuf. cost mousepad, there really won't be another technique.
Your muscle memory is more accommodating than you think- slight bio mechanical differences in moving your wrist a certain way would make much more of a difference in the perceived force required to move the mouse.
