Kingston FURY Beast or gskill.. DDr5 for the 9800x3D?
1 reading
8.2K views 4 replies 4 participants last post by  Pricktator
#1 ·
helo from these 2 kits which is better in terms on performace and qUALITY?
i am between these 2 kits
Kingston FURY Beast KF560C30BBEAK2-32 -> EXPO (AMD Profile) DDR5-6000 CL30-36-36 @1.4V (42mm heatsink)
G.Skill Trident Z5 Neo RGB F5-6000J3038F16GX2-TZ5NR -> EXPO (AMD Profile) DDR5-6000 CL30-38-38-96 1.35V (42mm heatsink
which from these 2 is the best for gaming and for the 9800x3d?
#3 ·
There both very close in specs the Kingston Fury has a little lower cas latency. They both have AMD Expo for OCing ease with the speed and voltage in the ram. I personally have the Kingston Fury Beast in my rig now and its been very good to me being OC'd. Im sitting at a stable 7200MT/s and volage at 1.5v really efficient modules. Yes the higher the Mhz you run will help with over all system performance and FPS. Ive seen a about 10-12 FPS more benching from stock 6000MT/s. What mobo do you have? I have just 32gb was thinking of 64gb, but 32gb its plenty for me i don't use CAD or heavy memory intensive programs.
#4 ·
I recommend the Kingston Fury Beast, as I have it in my rig and it's working fine.
Probably the G.Skill Z5 Neo doesn't have a thermal pad on the PMIC, so try to avoid.
You won't see such a performance boost with your 9800x3D with a high frequency RAM compared to a processor without the 3D cache, so put elsewhere that price difference.
Reactions: gupsterg
