I've been trying to lower my MacBook's CPU temperature so that it no longer thermal throttles.
Picture 1 is what it looks like without any mod. The heatsink is inadequate for a CPU with cTDP of 65W.
I was thinking about adding a copper plate (~1mm) on top of copper shims (~1mm as well) and connecting the whole thing to the aluminum bottom cover.
Picture 2 is with copper shims and picture 3 is copper plate over copper shims.
There's around 2-3mm of clearance between the heatsink and the bottom cover, so the copper shims and plate should fit fine.
Picture 4 is what the inside of the cover looks like.
So to recap, I would like to add copper shims over the heatsink, then a copper plate over the shims and then connect the plate to the aluminum bottom cover.
My question is, what kind of TIM should I put between the heatsink, shims, plate and cover? Thermal tape, paste, pads?
Thanks.
Thanks.
