Need help with overclocking Intel Core 2 Duo E6750 (on air)
2 reading
4.9K views 28 replies 4 participants last post by  Centurion855
#1 ·
Hello guys
I have recently joined this forum because I require expert help with overclocking my dual core E6750.
I would like to get it from it's stock speed 2.66Ghz to 4Ghz unstable (or stable but that seems a bit much) and to 3.60Ghz stable.
I have already done some provisional stress testing in Prime95 and my E6750 was stable at 3.60Ghz for 8+ hours. More stress testing yet to come since 8 hours isn't long. I aslo monitor my temperatures with the latest version of RealTemp.
The problem I have been having is that whenever I go over 3.80Ghz (475x8) my BIOS M.I.T. settings resets itself to 2.66Ghz. Does anyone know how I can prevent this from happening? I already have BIOS feautures like "thermal monitoring" and "enhanced halt state" set to [disabled].
Here is a picture of my advanced BIOS feautures:
And here is a picture of my M.I.T. frequencies @ 3.72Ghz:
M.IT. voltages @ 3.72Ghz:
Of course I have invested in better hardware in order to overclock my E6750. That's why I bought a Scythe Mugen Max + optional second fan instead of the intel stock cooler. And I also bought faster 4GB DDR3-1333Mhz RAM instead of my previous 4GB DDR2-800Mhz.
Here are my full system specs:
CPU: Intel Core 2 Duo E7650 (2.66Ghz stock speed)
CPU Cooler: Scythe Mugen Max + optinal second fan
GPU: XFX Geforce 8500 GT
RAM: Corsair XMS3 4GB (2x2GB) DDR3-1333 CL9
Mobo: Gigabyte P35C-DS3R (updated BIOS to latest version which is F12)
HDD: Seagate Barracuda 7200.10 250GB 7200RPM
PSU: Aopen Z400-08FC 400W
OS: Windows 10 Home 32-bit (will change to 64-bit soon, installed 32-bit by mistake...)
Thanks to anyone who can help me out with this and let me push my CPU to 4Ghz.
#4 ·
I don't know. I just know that overclocking with a low-quality PSU can be dangerous. The iGreen might not be a good choice either. Judging from professional reviews, that PSU is 9 years old. I don't know if I could support using that PSU in good conscience.
When you're overclocking, your system becomes way more sensitive to the quality of the power that the PSU is delivering - especially the CPU. If that power is too unstable (too much ripple, even if it's within ATX spec) and/or too inaccurate (loose voltage regulation, even if it's within ATX spec), then you could end up with problems.
#5 ·
I know the iGreen isn't exactly an excellent choice either but I can buy it from an acquaintance for a very cheap price. A completely new 600W PSU would cost me way more. I'm willing to take the risk of overclocking this system, it's a 7 year old backup pc anyway.
Any ideas on what the cause might be of the MIT settings dropping back to 2.66Ghz as soon as I go over 3.80Ghz? Could it have something to do with the ram timings / voltages ?
Which MIT values do you recommend to reach 4Ghz on my system? I take full responsibility of doing this knowing that I could potentially kill this computer.
#7 ·
Hmm yeah true 3.80Ghz is already high but I want to push it a little higher to 4Ghz. If I burn out the chip I can always get a used one for like € 5 -10. Which settings should I adjust to make it more stable given the pictures that I provided? I don't think I can increase my Vcore even more because it is already at 1.8Volts. And when I put it at 2.0Volts which I already did once my system won't boot / goes into boot cycles and then I have to reset the CMOS with the jumper. I think my cooling is sufficient because my temps don't go so high (never above 75°C so far) it's just something else that makes the clock speed revert to 2.66Ghz
#10 ·
Which model of memory is it though? The speed and CAS# latency doesn't tell us anything.
The iGreen PSU probably won't deliver stable and accurate enough power to get a good stable overclock that high. I'm not trying to say that you shouldn't attempt it because you're not afraid to kill this computer, but still.
#11 ·
I posted it under my full system specs: "RAM: Corsair XMS3 4GB (2x2GB) DDR3-1333 CL9 1.5V"
I just mounted the new GPU (GTX 560) and PSU in my system and it boots. Re-mounting that huge CPU cooler wasn't fun...
Anyways going to try to overclock higher than 3.80Ghz. But I will start from 3.60Ghz at which it was stable for 8+ hours in Prime95 Blend and work my way upwards in 5Mhz increments.
Hopefully the issue of resetting itself to 2.66Ghz will now be resolved... atlhough I doubt it.
#12 ·
That board supports DDR2 and DDR3, and iirc wasn't the best board for overclocking. FSB limited.
#13 ·
Correct it supports DDR2 & DDR3 but not at the same time though. So I replaced my Apacer 4GB (2x2GB) DDR2-800 CL5 sticks with the Corsair XMS3 4GB (2x2GB) DDR3-1333 CL9 sticks in order to reach a higher overclock without going past the speed that the RAM was rated for. With the DDR2 modules I was reaching speeds like 950Mhz with the lowest possible multiplier (2.00) which is way past 800. I don't have that problem anymore with my DDR3-1333 modules but it does reset itself to 2.66Ghz as soon as I go higher than 3.80Ghz (475x8). Hopefully that will change with the new power supply. I'm stress testing now in Prime95 at stock speeds with stock voltages to see how stable my system is with the new PSU.
#14 ·
475FSB is pretty high. Supporting both DDR2 and DDR3 means you have more options but also means that it can't do either as well as a dedicated board.
Lower your CPU multi to isolate the FSB and see how high you can go using NB voltage (and other advanced tweaks if they are available). Iirc DDR2 and 1:1 FSB:RAM ratio was best combo on P35/P45. Most overclockers avoided the "C" boards when the boards were new to market.
I think I ended up at 3.8GHz 24/7 stable on the e6750 abit ip35-e (variable resistor modded) system I built for my mother in law.
Iirc 500FSB is tough to get on that board and not guaranteed.
CAS9 is a lot of latency for 1333. I'd have to have CAS6 or 7 to be satisfied. I'd use DDR2 1000 with CAS5, but getting low latency DDR2 might be hard these days. I was using the D9 DDR2 800 4-4-4-12 sticks in my P35/45 projects back in those days. They overclocked to 1250 5-5-5-15 for benchmarks, but I ran them 1150 5-5-5-15 for 24/7 use.
I'm sure there are some old threads covering this board, it's limitations, and possible ways to overcome them if you do some searching.
#16 ·
So would it bet better to use my Apacer 4GB (2x2GB) DDR2-800 CL5 sticks for my overclocking endeavors?
Btw I isolated the problem: What happens is when I go over 3.80Ghz (475x8) the "CPU Host Clock Control" resets itself to [disabled].
I have advanced BIOS feautues like "CPU enhanced halt", "CPU thermal monitor 2" & "CPU EIST" already set to [disabled].
Here's a picture:
Any ideas? I mean this is overclock.net there must be someone around here who holds the key to the solution.
#17 ·
I would turn TM2 back on as it will protect your CPU from thermal damage.
Did you try reducing the CPU multi to isolate the RAM/FSB? See if you can get the FSB higher without taxing the CPU too much, and play with other BIOS settings to try and stabilize the NB. Once the NB is stable raise the CPU multi back up and focus on the CPU speed.
I would try OCing with both sets of RAM and run tests and benchmarks to see what gives the best results.
#18 ·
Ok I will turn TM2 back on. And I have tried lowering the cpu multiplier to 6x and the raising the FSB higher but as soon as I reach 3.80Ghz (635x6) the CPU host clock frequency resets itself to [disabled]. All other settings stay the same. How do I stabilize the Northbridge voltage? Do I need to increase (G)MCH OverVoltage Control for that?
#19 ·
You don't need to go that high on the FSB. Since you're back at 3.8GHz it'll be hard to tell if it's the CPU or NB holding you back.
Yes, MCH is NB voltage.
Iirc, it is tough to get 4GHz on e6750.
#20 ·
Just to put this into perspective, I had the E8400 in the EP45-UD3P, and as you know its stock speed is 3.0 GHz. Also, 1 GHz overclocks to Core2 CPUs was considered to be a big and respectful overclock. Anything above that, and you're looking at needing water cooling.
So, I had the E8400 @ 4.05 GHz and making it go higher than that with my Tuniq Tower 120 was difficult, at best. I got it to 4.2 GHz for a few minutes, but my temps were way too high, easily reaching the 90s with Prime95's Small FFTs test. The voltage had to be stupidly-high too.
In other words, I wouldn't expect much more than 3.66 GHz if you want a rock-solid stable system.
