Todd Haselton
August 03, 2007
[Source: Ars Technica]
August 03, 2007
Hitachi and NEC are developing the water-cooled hard drive systems for desktop computers mainly to reduce noise levels to 25 decibels, 5 decibels quieter than a whisper. To do this, NEC and Hitachi actually wrap the hard drive in "noise absorbing material and vibration insulation." Further, the companies have chosen to use a low-speed radiator fan to keep decibel levels down in the radiator also. Creating a quieter hard drive isn't the only focus though, as the companies also hope to keep the hard drives cooler. According to Hitachi and NEC, the cooling cold plate they're planning to use is the most efficient plate ever used for heat conduction, which means they'll be able to cool the hard drives quicker and more efficiently. The cooling plate technology uses a series of fine ridges, similar to the ones in CPU cooling plates, that are just 0.09mm in width, and through which anti-freeze liquid will travel. Since water-cooling technology is relatively old, we imagine Hitachi and NEC set out to create a quieter hard drive, and the best way to achieve this was to wrap it in the noise-absorbing material. Since that material likely heated the drives more, the most practical option was to water-cool the drives. |
