Nvidia GTX 750 Ti and 4K for MoVies Only?
35K views 4 replies 2 participants last post by  S_V(TM)
#1 ·
Hello Everyone,
After Various google Search and I came to know that GTX 750 Ti supports 4K TV's but at the same time I am really confused.
Please clarify few things to decide whether to Buy now or not.
I purchased 4K TV and looking to play my Blu-Ray (1080p) collection in this TV through my PC. My question is
Out of the Box, Will this GTX 750 Ti card runs 4K 3840x2160 Resolution (Which is my TV resolution) ???
If so at what Refresh Rate , 30hz ? I read that to get 60 hz I need to connect with Two HDMI outputs.
Doubt 1 : If 3840x2160 @ 30 hz, What are the Problems I could face with Blu-Ray Movies or any other ?
Doubt 2: With Single HDMI output from Card to Single input of TV through HDMI works , right ? Or need to use any kind of adapter in between to get 3840x2160 resolution ?
I don't care about games at all.
Movies is my TOP priority. For Audio I will run optical cable from sound card to my speakers. For Video , I want to run HDMI (single output from card) to TV HDMI input directly.
My Priority is to make my PC (With GTX 750 Ti) work with my 4K TV for playing 3D Blu-Ray content with no further Budget.
Please help me....
Regards,
SV
#2 ·
I think the first thing you should check - does your TV have HDMI 2.0 [or a Display Port, of which I would highly doubt]? If it does not, you won't be able to get 4k @ 60fps no matter what video card you have.
Second, the only way that you'll get 4k @ 60fps with a 750ti will be through a Displayport to HDMI 2.0 adapter, otherwise using HDMI you will only get 30fps (which is more than adequate for movies as they are typically shot at 24fps)
So if for some reason you didn't find your answer to what you were asking in the above information, yes your 750ti can display 4k, it will do it @ 30fps with a single HDMI cable.
Reactions: S_V(TM)
#3 ·
Excellent sir....+rep
That is what I am looking for. So with Single HDMI from card to TV will output only 4K ( 3840x2160) 30 fps then. Looks like I have HDMI (4K,60p) it says in Terminals side list.
If it is for Movies only.. Can I go ahead with this Card? Please suggest
EVGA 750 Ti 2GB
sorry for not mentioning about my TV model..
LG 55UB850T
Thank you once again.
#4 ·
Reactions: S_V(TM)
