I have an ASRock Challenger D 6650 XT that I've been overclocking/undervolting. I needed help to see if I'm doing this correctly.
Currently I have the clock speed set at minimum freq to 2950MHz, max freq to 3050MHz, voltage to 1040mV and memory to 2400MHz.
I'm running a custom fan curve. Fan push to 90% during benchmarks. Benching temps max out at 65C GPU and 92C junc. It usually stay around 55ish GPU during gaming. The card pulls 165w while benching and a little over 110w while gaming.
I've ran Time Spy demo multiple times as well as played several games and haven't had any driver crash or any issues.
Is this considered stable or am I missing something? Also are the temp ok? As far as gaming goes, I have lower temps with the OC than when settings were stock.
Finally if temps are good, should I push more voltage for higher clocks or leave as is?
Thanks in advance for the help!
