p8z77 v-pro Can't get into BIOS, straight to windows 7? Any advice welcomed
2 reading
6K views 7 replies 7 participants last post by  banwell
#1 ·
I updated my asus p87zz v-pro to the latest bios 1504. It fixed some issues I was having playing guild wars 2 and actually corrected the crashing issue I was having. I got my pc oc'd to a little under 4.7 with ease and want to try a little higher. The issue is, I can't get into my bios. I tried mashing del the bios button, holding keys to get error when booting , unplugging monitor, etc...The pc is running great but this not being able to enter the bios can't be good. I have searched and searched but can't find a solution .! Desperate for advice, thanks in advance.
#4 ·
Little old and you've probably fixed it already but with FAST POST I get this problem too at times (here and there). When it fails I just turn the computer off at which time it uses normal POST (as that's what I've set that to) which always allows BIOS entry as it's slower.
#7 ·
Are you running a mechanical USB keyboard? Try a PS/2 keyboard.
LOL, I didn't realize how old the thread was.
