Hi all,
I have the following problem. In GPU-Z I can see that the Bus Interface status is PCI-E x16 @ x2. The system is in my sig. Isn't it supposed to be PCI-E x16 @ x16? I believe the mobo supports it (has two PCIe x16 slots - one @ x16, the other x1 ot x4). The VGA is plugged in the blue slot (the x16 according to the manual).
Tried the settings in BIOS. Only relevant PCIE settings there are boot priority (?) PEG/PCI ot PCI/PEG and PEG Port Control (Auto or Disabled).
What could be the cause here? BEcause now, I'm using only 1/8th of the data transfer rate, as it seems.
This is a shot from GPU-Z: Attachment 99125
It's not only GPU-Z, Everest also reads these values....
Thank you in advance for your help
