Power Supply Does Not Have 8-pin CPU power?
35K views 8 replies 6 participants last post by  Hitoshi
#1 ·
I had to put a computer together fast for a cousin of mine and I ordered:
APEVIA ATX-CW500WP4 500W ATX Power Supply
ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
I just got finished putting everything in the case and when I go to unwrap the tied PSU cords I realized there is only a 4 pin for the CPU and the motherboard has a 8-pin CPU power plug.
Power Supply includes:
1 x Main connector (20+4Pin)
1 x 12V (P4)
4 x Peripheral
4 x SATA
1 x PCI-E
1 x Floppy
Can I do anything to make it work or do I have to buy a new PSU?
Computer build includes:
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
Patriot Gamer 2 Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model PGD38G1600ELK
SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity (100315L )
Any help would be greatly appreciated. I should have had this computer built for him yesterday but its finals week and I just haven't had time to mess with it.
Edit** I am thinking about getting APEVIA Model CVT48 9.5" 4 Pin P4 /12V to 8 Pin P8 /12V Power Supply Converter Cable But I do not know if that would work correctly on the motherboard or with that power supply because I have no experience with them.
#2 ·
My recommendation is to get a better power supply that has the 8 pin 12V EPS power connector which is standard on most well-known power supplies. Never ever go cheap on the power supply--it's one of the most important components in the system. Get a CORSAIR Professional Series HX850 or better.
#3 ·
Are you sure that there aren't 2 4pins? At least for mine I had to connect 2 of them together in order for it to work.
#4 ·
I was with you until you recommended an 850W power supply, and a dated and overpriced one at that.
The computer in question will pull less than 400W. A quality ~500W would be ideal.
#5 ·
You will be fine with that power supply. The 4 pin CPU connector on your PSU will fit into the 8 pin socket on your motherboard and power it fine. You could buy that adapter if you want, but it really isn't necessary. The 4 pin will fit into the 8 pin socket, and only in one direction, so you can't really mess it up. But you might want to consider a higher capacity PSU in the future for sure.
#6 ·
But that would leave 4 pins without anything connected to it? You can hook a 4-pin straight up to a 8-pin?
On a side note, I was looking at a spare computer in another room and it has a 400W Corsair with 2 4-pin CPU connectors on it that I can use. Will a 400W power supply be enough for this machine?
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply is the one in the other computer I am about to swap out if yall think 400 watts is enough. Since the other computers mobo only requires a 4-pin CPU connector.
