I picked up the above RX 6600 XT at Micro Center on the 11th for $399. Because this card just hit the shelves I downloaded the latest beta of HWiNFO64 today. After running Microsoft Flight Simulator for an hour at 1440p high preset maximum temperatures Celsius were:
GPU Temp = 62.0
GPU Memory Junction Temp = 56.4
GPU Hot Spot Temp = 83.0
I know those are within tolerances however I would like to get hot spot temperatures down. Would thermal pads help, and if so what type and thickness do you recommend. I have looked for a teardown of this card however, haven't found any yet.
Also, the card has a back plate for support only. There is no thermal pads on the back side of the GPU to connect it to the plate for heat dissipation. Again, would thermal pads be of benefit and if so which ones and what thickness.
Thank you in advance.
GPU Temp = 62.0
