Hello all.
I just posted a question re. direct-die mounting a Noctua cooler here;
www.overclock.net
Has anyone had any success pre-forming a smooth gallium/copper layer on a fresh copper plate prior to installing a cooler?
I've seen a few examples where people have found they end up with more stable LM after several re-applications have formed such a layer (but usually with some pitting), presumably after many heat-cycles.
To re-iterate from that post;
I was thinking of perhaps roughening the plate with 1200-1500 grit, warming it to as hot as I can hold, then going though several passes of 'massaging' LM (or pure gallium) into it to (hopefully) pre-form a stable (and smooth) gallium-copper alloy layer.
I happen to have the gallium to hand as well as Conductonaut and CL Liquid Ultra (the gallium is a lot cheaper and I have much more of it).
I know I should just DO IT and then report the results, but the problem is that I don't want to possibly pointlessly ruin the NH-D15S.
(Maybe I could/should get some copper sheet to experiment with)
ETA >> I'm thinking that IF this worked using the pure gallium rather than the LM intended for installation then there might still be some migration of the other metals in the LM into the contact plate.
Noctua direct-die?
Greetings. I've prepared a PTFE PCB shim for an i7-9700K (starting with 1.0mm, stuck to a block with double-sided tape and ground down to the c. 0.85mm needed) to direct-die mount an NH-D15S. I've also modded the stand-offs and thumb-nuts on the Noctua mounting hardware for the right...
