81 - 100 of 124 Posts
Discussion starter · #85 ·
update # 12
almost finished. i need to start on my false floor and front fill pannel
Discussion starter · #87 ·
Originally Posted by Pic0liter View Post
Awesome work! True inspiration for us Rocketfish owners.
thanks. should see it with my rad mounted
Discussion starter · #91 ·
well im going to prolly ditch the drive bays if can get a MM 3 bay Drive Bay, it should give a cleaner look inside. also im goign to get a MM harddrive rack so i can mount my HD nicly under the floor, and have it look nicer than the stock HD holder
Discussion starter · #92 ·
i went to home depot and got some the the aluminum for my false floor. i picked up 2 lengths of L channel. now i need to get the aluminum panel to cover it. ill prolly get that some time next week
Discussion starter · #94 ·
i know its not done. but someone could comment on so thing. or do you want to see pictures of my cat again?
Discussion starter · #96 ·
not bad. i need to do mine like this because my mobo tray is bowed. and it needs to support @ least one pump. i rather make it more structural.
Discussion starter · #98 ·
Originally Posted by TheCh3F View Post
Looks great so far whe3ls. I'm excited to see the final product.
me too. mainly all i have to do it finish the floor and front panel
I did mine using L channel as well. It felt too flimsy without it. It was a pain to put in though. The cuts weren't perfect and it needed a little push to fit inside nicely. I put the floor and L channel together then put it inside the case. I put a divider thing between the psu and hdd bay to cover all of the extra cables and that made installing the false floor that much harder. I had to install the psu, hdd bay, and divider all prior to putting the false floor in.
Discussion starter · #100 ·
i mine go in really nice and easy. i did 45 degree cuts on each end.
update # 15
i got the rails to fit much better. i still to make the front rail.
my mess
my new board
