Reservoir tubes that fit EKWB
2 reading
721 views 2 replies 2 participants last post by  lordkahless
#1 ·
Hello,
I have a Quantum Kinetic TBE 300. I am updating the layout of my PC and want to downsize the length of the reservoir. This model comes with the EK-RES X3 - TUBE 250 (204mm) model of tube. This will be a tad too long. You can order replacement reservoir tubes from EK but the next size down is EK-RES X3 - TUBE 150 (104mm). I don't see anything between 204mm and 104mm. Has anyone had any luck ever buying a different brand of reservoir tube and having the diameter of the tube, threads, etc work out for an EKWB quantum kinetic pump/body.
Thanks
#2 ·
Have you considered trimming it to the wanted length yourself?
