supposedly goes for sale for 1500 USD in july? will update as information is provided.
buy here:
https://www.amazon.com/Samsung-Screen-LED-Lit-Monitor-LC49HG90DMNXZA/dp/B072C7TNC5
more info here:
Source
the vertical dimensions of this monitor, counteracted by how far back you will need to sit in order to see the entire thing, the 1080 vertical resolution will not be noticable. It would be a waste to use 1440, especially since this is aimed at gaming,and not productivity (not that it would be bad at productivity). More likely to be able to achieve higher refresh rates with this resolution.
IIRC, 3 things determine how we percieve a monitors pixel density. how close you sit to the monitor. how big the monitor is. and the resolution of the monitor.
You can certainly find out, but first you must defeat his twenty-seven lieutenants.
