SOLVED!PhysXLoader.dll missing but im using a AMD video card
47K views 11 replies 6 participants last post by  noobdown
#1 ·
OK i got a XFXHD 6870 2GB
this morning i installed NFS SHIFT2 and when i launched the game i got this BUT how is it possible to get physX to work with an AMD VIDEO CARD?? i really wanna play the game :/
#7 ·
If that doesn't work or if the game crashes while playing you can always download the current version of PhysX directly from the NVIDIA website.
Though you have a AMD card some games still require PhysX to run. My NFS Shift 2 kept crashing with the PhysX version packaged with the game but a PhysX update fixed everything.
P.S. I also have an AMD 6 series card.
Good Luck.
#8 ·
IVE INSTALLED the latest physX from the site i launched SHIFT 2 and every thing worked out gud but ive heard people using AMD AND nvidia cards BUT ive heard that its kinda tricky and complicated because i got a GTS250 laying around in its box
#10 ·
It's normal. Some games require the physx dll because they ARE physx enabled games. Metro is another that will not run straight out of a fresh install if you have no physx installed.
