something throttling my sandy bridge, help!
7.1K views 86 replies 12 participants last post by  Sharky[SVN]
#1 ·
I need some help overclocking my 2600K
I've set multiplier to 44 and voltage to 1.300V, and RAM on XMP profile (1600MHz, 1.65V)
but no mather what test i run (intel burn on maximum), frequency wont run at overclocked, but on something like 3.5 or 3.8GHz
and this also happens if it's OC-ed only on 4GHz
temperature doesn't go over 65 degrees on 4.4GHz OC with maximum intel burn test
what is throttling this? speedstep?
#77 ·
Yes, I have tried everything (except contacting intel lol)
this has become ridiculous
I've now loaded default settings and raised nothing but multiplier to achieve 4.100 MHz and now tested with LinX program - it locks to 3.9GHz
O
M
G
i'm going crazy
#79 ·
yes
but did I mention that when testing with SuperPi, frequency always goes up to maximum overclocked
why not with other programs?
i'm starting to think it's software problem
#81 ·
omg, could it really be PSU problem? I've calculated power consumption with http://www.thermaltake.outervision.com/Power tool and it recommended me 850W PSU (if overclocked to 4.5 GHz, if not 612W lol?), I have 700W :S
#85 ·
Originally Posted by munaim1;13454812
It has been happening to others aswell. Check this out: HERE
so it is the motherboard
oh well, i'll just keep it at 4.5GHz...
I've tried 5.0GHz on 1.36V and the computer freezes after a minute in Windows, 4.9 GHz works fine and Intel Burn tool on standard stress level goes through, but on next high level it shows warning that cpu isn't stable. I don't want to go any higher with voltages...
anyway, thank you very much for your help, at least I know the cause of problem now...well partially
#86 ·
I've tried 5.0GHz on 3.6V and the computer freezes after a minute in Windows, 4.9 GHz works fine and Intel Burn tool on standard stress level goes through, but on next high level it shows warning that cpu isn't stable. I don't want to go any higher with voltages...
3.6v? Holy moses
I am suprised your chip is still alive!
#87 ·
Originally Posted by stuiees;13456574
3.6v? Holy moses
lol my bad
i meant 1.36V
