Supreme FX II in a Non-Asus Mobo?
31K views 14 replies 9 participants last post by  Marc Wolfe
#1 ·
Hi I just build my new PC with a Asus rampage extreme, Becasue i already have a good PCI sound card i wonding if i could use my Asus Supreme FX II inmy old PC which has a non-asus motherboard.
Any ideas would be great
#8 ·
The physical design of this slot is similar to PCI Express x1 but turned by 180 degrees, however there is no electrical compatibility with the PCI Express x1. The thing is that Supreme-FX is actually not a fully-fledged sound card, but simply an analogue part of the sound tract connected to the AC97 interface. That is why you can only see a one microchip on the Supreme-FX card: the high-definition 8-channel Analog Devices AD1988B codec.
Source
It doesn't look good mate.
EDIT : Oops that's the FX I so I'll keep on digging.
Ok it's a standard pci-e x1 slot however I'm not sure that it will be able to work as there are some audio components that are on the mobo. Good luck to ya.
#11 ·
It won't work, I tried the same thing with my P5N32-E. And I am pretty sure the sound card is the equivalent to onboard.
