[TH]AMD Ryzen 5 2400G Review: Zen, Meet Vega
23K views 152 replies 70 participants last post by  Particle
#1 ·
Man, this thing looks impressive! 1080p is very strong!
But the addition of AMD's Vega-based graphics engine is what everyone was holding their breath for. That combination of new Zen cores with modern 3D capabilities played well together throughout our benchmark suite at 1280x720. It also earned approving nods in most of the 1080p-based tests. The previous-generation A10-9700 and Intel's current UHD Graphics solution simply get slaughtered when they show up in the same charts.
http://www.tomshardware.com/reviews/amd-ryzen-5-2400g-zen-vega-cpu-gpu,5467.html
#2 ·
Impressive is an understatement. That thing is demolishing Intel's counterpart and beating a discrete CPU+GPU combo in most tests, with good minimums too, for less than $200. That's tremendous value.
#3 ·
Looks nice.
#5 ·
2400G , 8GB 2400mhz ram and asus A320M-K for €350 on amazon. (8GB Ram being 100€)
#6 ·
I wonder if they moved away from solder because of the GPU?
If Ryzen 2 coming out in the next few months has TIM instead of solder... I don't know how AMD can use the Black Edition label with a straight face.
#8 ·
Previous FM1/FM2/+ APUs and CPUs also used paste instead of solder.
#9 ·
But how well does it mine?
#14 ·
Interesting.. Do you think this would make a good choice for an HTPC? For some reason Plex won't stream in original quality HEVC videos to my old laptop anymore. I have to play them through the network drive using VLC.
#25 ·
Should we expect a more powerful Ryzen 7 version?
#32 ·
According to what has been said already, there is no plan for a Ryzen 7 version. Why would you even bother though? Ryzen 7 isn't really for gamers. :p The highest I'd go is the 1600 and that's it.
#26 · (Edited)
#27 ·
So these processors are already part of the new ryzen refresh?
What do you think this means for Ryzen 7 CPUs? Will we see any signifikant improvements (10-20% more performance due to more mhz and/ or higher IPC) or just 100-200mhz and a few percent in some tasks?
#29 · (Edited)
This line needs a 95W product so badly. Make a Ryzen 5 2600G with 4 cores 8 threads that clocks up to 4Ghz on turbo and increase GPU core count to 1024, then I'm sold.
Why the hell they limit themselves to 65W when their platform is 95W capable is beyond me... Perhaps AMD really likes the term "underdelivering company" and wants it stuck with them.
Another thing about memory bandwidth:
It's quite clear that these GPUs severely bottlenecked by memory bandwidth as DDR4 3200Mhz at 64bit is barely enough. Yet Ryzen's IMC still can't handle anything faster than 3200. Keep in mind AMD, if you are going to make an APU, next time make sure your IMC design is top notch and can handle speeds above 3200Mhz. I know Intel also officially supports very low speed ram but it's a breeze to run 4266Mhz ram with 8700K.
There are kits out there that clocks up to 4700Mhz... sure that's extreme, you don't have to go that much, at least let some of us go up to 4000 by overclocking to remove that bottleneck... I have never seen any Ryzen chip that can run any ram speed above 3600mhz and even that's very rare and happens with cherry picked samples.
Amd = late & weak.
#42 ·
1) 65W means nothing. It will not improve overclocking.
2) 1024 CU will do nothing since it held back by Memory. Stock 704 CU card is 1250MHz and can OC to 1650MHz but the gains are not that crazy.
3) Sure faster memory support is nice but this is a budget solution and 3200+ is not budget.
#35 ·
Good review.
#36 ·
Throughout this review, cpu and gpu have vowed, in our presence, to be loyal and loving towards each other.
They have formalized the existence of the bond between them with words spoken and with the giving and receiving of infinity fabric.
Therefore, it is my pleasure to now pronounce them as Ryzen APU's.
You may now kiss your dies!
#37 · (Edited)
Quite literally in fact as one may be able to potentially ditch the IHS completely and do direct-die cooling just with the stock heatsink since the CPU retention mechanism doesn't go over the IHS and the Wraith Stealth is a screw-on cooler.
AMD's use of TIM on lower-end CPU is not new as the Athlon II chips used TIM even though the Phenom II chips were soldered.
Heck I personally have delidded and done direct-die cooling with the stock heatsink on even an old Athlon 64 x2 (65nm variants were not soldered), though the stock heatsink in the AM2 days used a clamp and therefore I needed to add a shim in order for it to make contact with the die.
#41 ·
definitely worth the price, this literally satisfies most games running with less than max settings.
but its so close, if they double the IGP performance then they'd be able to close in 60fps @ 1080p max in most games.
the next generation APU is something everyone can look forward to.
#46 ·
Nice MSRP, but thanks to gpu shortage, that price is going to go up, at least $130 imo.
