4,3GHZ locked chip would likely outperform Intel's Iris solution.
(95W part clock's 3ghz when full GPU load)
A10-7890StiltOriginally Posted by mtcn77
Why isn't @The Stilt being credited with DPT software? I've heard it can shut down the unnecessary power management.
I mean the reviewer could take it into consideration before sentencing us to a 3.0 GHz review.
I think FormatC is the reviewer. This is what he has to say:
The same cooler can cool FX-8370 even at 4.9GHz.4.) It is possible to break this barrier with manually changed BIOS settings, but this is more than this cooler will survive.
I measured in worst case above 150 Watts for this APU - too much for the Wraith cooler and at the end totally senseless.
because some people don't want to spend an extra $300 for a gpu just to play games. If intel can somehow get a 980m and cpu to work as one they can win but as far as I know it AMD has the better APUOriginally Posted by hojnikb
Another pointless APU. I still dont know what people see in them. iGPU performance is poor and cpu isn't the best either.
And they still haven't fixed the cpu throttling.
What a waste.
I wish intel would release HD550/HD580 in desktop cpus like i3/i5. Would totally kick amd in the iGPU butt![]()
You really don't need to spent 300$ to game. You can grab 250x for cheap.
its for ease of use. Some ppl (like me) get these to build computers for second hand use and don't want to have the hassle of looking up spec for a gpu and hooking up the gpu when all you need is just the cpu to do both.Originally Posted by hojnikb
And looking at the whole platform cost, a 250x and a cheap pentium/athlon will cost less than expensive 7870/7890K and faster ram (because you need it to take advantage of the iGPU).
From a price/performance perspective, apus (especially higher end like this one) make no sense.
I didn't have any throttling on my 7850k, though I don't know if that chip had issues. Also, the iGPU really isn't that bad, and these chips can do well as an htpc.Originally Posted by hojnikb
What a waste.
This too. Good point.
Its a very poor argument really.
Every APU throttles to 3Ghz when iGPU is used.
for you, yes. but to others it's a justifiable choice.Originally Posted by hojnikb
tell me a situation when buying apu is justifiable but pentium+250(x) isnt ?
ease of use
In that case, you're better off with a used setup. You get A8 7600 for that kind of money. Thats the slowest 4 core apu (i'm not gonna count 2 core apus, because they are trash).
Yeah ? You're buyinga bottom barrel system to play that ?
How is apu easier to use ? explain that ?
