TS Bench Competition
13K views 12 replies 7 participants last post by  ducrider
#1 · (Edited)
Leaderboard Updated December 8th, 5AM
You can download the latest version of throttlestop here:
ATTN: Choose this exact release, its 9.4.2 Beta
Download ThrottleStop 9.4.2 Beta | TechPowerUp
we all need to be working from the same benchmark engine version
To begin, open throttlestop and select TS bench at bottom of your throttle stop application
Please include CPU and MEMORY tabs from CPUz in your sub as well, this will make it easier for me to fill out the leaderboard later on. Please follow a similar layout if possible... so this will be your sub, which will show us peak temps as well
We will do one bench for single core performance and then a second bench to see how well your processor scales with a 20 thread workload. Please mirror all other benchmark options for consistency as in the example result above. So run both tests and then snip your results and submit them w/ OC data, leaderboard to follow. Good Luck Gentlemen!
#3 ·
Cmon guys, this is a relatively obscure benchmark, lets try to generate some interest. New benchmark engines are always fun :)
#9 · (Edited)
Default
Reactions: storm-chaser
#10 · (Edited)
Somehow I can't get threads 1-20 to show in same window:
Full CPU clocks: 54/4/3/3/3/3/2/2 49x Cache 0-AVX Offset 1.304v at max load, daily stable.
#11 ·
Leaderboard is up guys. I've been awake for well over a day so if you see any errors please PM me and I will fix them. Also if you have any advice on the leaderboard layout, Im all ears. Thanks for being patient.
#12 ·
A huge shame Ryzen isn't supported, but here's a selection of benchmarks (just for fun as there's no CPU-Z screens and I'm using an older version) from my 15W Atom-powered, J5005-based HTPC (4C/4T). RAM is 2400 MT/s (I think) DDR4 CL16, currently with 2x8GB modules.
It runs very hot, as you can see, peaks at ~1.25V @ 2.6 GHz (all-core speed). Now compare that to my 5900X which under an all-core AVX2 load stays at ~69°C at ~1.17V. I still love the HTPC as it does everything I need it to do (HW decode HEVC, VP9, etc. in Kodi and 4K VP9 on YouTube).
