Hello all looking to upgrading my memory in my laptop. currently have 16gb. someone please help out looking to upgrade to 64GB.
My current Laptop:
MSI GF65
My current Laptop:
MSI GF65
From what the Amazon listing says, it's expandable up to 64 GB, which means the RAM should be modular and not soldered onto the motherboard.Not everyone can do that or are willing.
For regular office work on Windows 10/11 16GB is the confortable minimum I would use. Given the model of OP's laptop I would assume gaming is the main use, so for that 32GB minimum.
I would try to hunt down the service manual for the laptop first or some sort of in-depth spec. sheet to eyeball the layout and components. If you can, open it up to actually look inside. Some laptops have soldered components, or just have a cumbersome layout that could make swapping out components troublesome. Also, be aware that some laptop BIOS have arbitrary restrictions in terms of hardware.
Highly recommend you stop by a computer store. They won't charge you any extra to recommend what RAM to buy.Perfect ill be going the ones you recommend; unless anyone else has other options. Currently i have 16GB and I'm using 89% of it. definitely want all 64GB lol Thanks much.
EDIT: will these even fit in a laptop?
Amazon.com
Has two SO-DIMM slots and should handle 2x64GiB DIMMs without issue.MSI GF65
